Old 07-12-2023, 04:15 PM   #15
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
Maybe check with motion works on there catch can, I know you said the oil leak is at the bottom of the dipstick mounting. Motion works has a 2 chamber baffle system, and even vavle cover breather mounts, or valve covers . But they are very well trained and experienced at issues similar to this. Ok, you figured it out on the leak.
Revalot is offline   Reply With Quote
Old 07-12-2023, 04:33 PM   #16
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
New oring installed on dipstick tube , seems to be a bit tighter now inside the pan and not wobbling around earlier. I wonder if it wasn’t in all the way either.
Well going to take it out and see how it is. Let’s see how goes.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 07-12-2023, 10:39 PM   #17
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Looks like it might be fixed. I didn’t beat on it hard but I see no signs of oil leaking by the dipstick tube.
