Old 09-07-2023, 06:25 PM   #15
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Okay getting some results with temperature in the 70’s now. Pretty sure I saw Complete Street Performance going the 40’s & 30’s.. The bigger pump helps the flow but I am thinking of wrapping more hoses especially near the engine to help.
Had the car out for a 15 min cruise and let it idle for 10 mins then took the temperature on the cold line to Supercharger 73.2 F. I did read once in the 60’s.
Added a pic of the front grille and you can see the bigger PIERBURG CWA400 behind a custom grille I made. I decided to make 2 clips on the bottom of grille and 2 clips on the upper part so at the track I can just unclip the grille for better air flow into engine bay. Also I now have lower access to chiller and pump without taking off the front bumper.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-07-2023, 06:45 PM   #16
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
You’re getting there…! Are you 100% on the refrigerant charge being spot on?
Old 09-07-2023, 06:49 PM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
What are you doing with the car such that you need such low temps? Is your car a DD, digs, drags, track, or? Were you seeing a lot of negative advance or what?
I put that Pierburg on mine last month. Much greater flow rate.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 09-08-2023, 07:17 AM   #18
BlackbeastSS2
That’s my next move after I wrap some more lines, the shop where I do the dyno recharged the system. What’s the coldest freon I can get? Will have to ask what they use. Anyone with a chiller no the correct charge weight of replacement Freon? They didn’t no the correct number and didn’t want to over fill and then cause the compressor problems. So what is the required charge weight, no idea?
Instructions:
Step 1.
The AC system does not require additional oil. If charging the car multiple times do not add more oil each time.
Step 2.
Vacuum the AC system for 30-45min (check that it is holding the vacuum) If it isn’t holding the vacuum you have a leak you need to tighten your AC connections.
Step 3.
Put in the charge weight provided.
Old 09-08-2023, 07:25 AM   #19
BlackbeastSS2
The tune in the 800’s requires me to run either 98 octane or colder IAT’s to be safe as per tuner. I don’t have E85 in the area or I would have went a different route. I use meth for cooling and now a combination of chiller and higher octane. Car runs two tunes for strip and street.
Old 09-08-2023, 02:19 PM   #20
adamjwilson
Drives: 2022 Camaro 2SS A10
Very nicely done BlackBeastSS2
Congrats!
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 09-08-2023, 04:26 PM   #21
JSH
JSH's Avatar
Drives: '20 ZLE
What times did it run this year?
2020 ZL1LE A10.
Old 09-08-2023, 04:41 PM   #22
BlackbeastSS2
Zero times at the track, only Mexico so far. The plan is to have a few track days before the end of the season. I will post times then.
Old 09-08-2023, 09:29 PM   #23
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
I'm not a car ac guy but 50 years in the commercial/residential end. To my knowledge 134a is the only refrigerant used in late models. The charge is probably in the owners manual but when you add something in the system like longer lines or h/e then you need to add more refrigerant to fill it enough. That would be determined same as engine tuning according to conditions. Pressures and temps should be the same as stock.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 09-08-2023, 10:33 PM   #24
Joshinator99
Moderator
Nope, the Gen6 Camaros run R1234YF refrigerant not 134a. I’ve heard rumors that you can evacuate the system and run 134a in its place but haven’t tried it personally. I believe with an Interchiller there is a sight glass that you use to determine if the charge is correct.
Old 09-09-2023, 07:33 AM   #25
BlackbeastSS2
Yes you’re correct about the sight glass, I forgot about that. I will watch the sight glass to see if there is any bubbles in the system. It’s behind my pull out grille, so coming in handy already. I need to see at a shop that specializes in AC to get there opinion if I can use a better/colder Freon.
Old 09-12-2023, 01:20 PM   #26
ZO6Ted
Old badass
ZO6Ted's Avatar
Thanks for this guess my 2020 CC probably does too then. I need to check.
Old 10-07-2023, 08:35 PM   #27
oldman
Drives: SS 6 speed of course
My Camaro came with 134a, I ordered new lines (just in case I messed up my supercharger install) and they came with R1234YF fittings. Exact same part number.. I just got ebay adapters and run 134a.... don't tell anybody but in the old days when we were dumb or smart? we would jucie R12 with propane (R-290) and lines were bent copper from the hardware store, don't smoke during an A/C leak... just saying. But it would blow frost out of the vents in Hawaii after being park in the sun all day as I was surfing...
