Old 07-09-2023, 09:37 PM   #15
Originally Posted by Dynamical View Post
So I put the back seat down and at WOT it sounds pretty good for a stock car but it definitely needs full exhaust to sound good all the time. I think turning off the AFM/DOD will help the sound as well.
I love the fast snappy shifts this A10 does. Can’t wait to make it louder and faster!
This car moves out really well for a stock car
https://rumble.com/v2z4k6k-camaro-lt1-a10-fun.html
Heh, she's moving all right Interestingly you only get 1 "bang" shift from the A10 even though it has so many gears, guess I'd be happier with more but all shifts are nice and quick indeed.
Old 07-09-2023, 09:43 PM   #16
Kamero6
Drives: 6th Gen LT1
Thanks Kamero! I really like the A10. Very snappy and fast. The car already has 2500 miles on it. I bought it used. It had an oil change at about 2500 miles. What is the oil change recommendation for the break in?
About the AFM, I want to mod so that means my warranty will be gone. We’ll see how it goes
Great video, it sounds badass. I test drove a LT1 6M back in january with regular exhaust and it was kind of quiet. Same with my old corvette.
If you like it loud you can get a used sound tube and make it louder in the cabin. I don't know why people hate the sound tube or say it's fake. Apparently GM removed it at some point.
I'm still thinking on getting a M6 later this year. Do you still have 60k factory warranty even being the 2nd owner?
Kamero6 is offline   Reply With Quote
Old 07-09-2023, 10:33 PM   #17
Kamero6
Drives: 6th Gen LT1
Totally off topic, but have you thought about a Diff swap instead of starting with engine mods?
I did some research and since LT1's don't have diff cooling, a 3.27 LSD V6 diff w/o cooling should fit.
You get 18% more torque in all gears and 1st gear should be still usable . Other choices like 3.73 is too short and 2.85 is so close to 2.77 that won't be worth it IMO.
The torque boost would be equal to 536hp @ 6000rpm (Flywheel). Ofc the modded engine would have a different power curve and etc etc.. Just comparing 1 point.
The downside of this is that you loose some top end, you can only go 261 instead of 308 mph
Old 07-10-2023, 05:57 AM   #18
CHASLT1
Drives: 2021 Camaro LT1
My new A10 2021 LT1 felt 5 times faster than my 2019 C7 with the A8.
CHASLT1 is offline   Reply With Quote
Old 07-10-2023, 08:14 AM   #19
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
1 bang shift? Hmmm, do you think this is because I was only able to go WOT from rolls? I'm guessing the one in the vid I was doing maybe 30mph already. I'm assuming if I went from a dig I would get all the bang shifts you're talking about?
Circle on and off ramps on the highway is addicting as heck. Its been 7 years since driving my last fast car but I quickly remembered these cars have absolutely NO practicality for me. It is purely 100% FUN and trouble
Exhaust work and a range will make the driving experience so much better. I'll do the range first. I can already tell when it goes to 4 cylinder mode the exhaust loses its low tone cruising.
I like how I can control the gear cruising for fuel economy by upshifting to the highest gear.
I'm really hoping this car can be as trouble free as my last cars. I had 3 LS1 Camaros and they were rock solid
Yes, the original factory warranty is with me.
I actually watched that guy's videos a couple months ago while weighing out what car I should buy. I had no idea about the sound tube then but I can see my car has a plug there. I'll have to look in there more to see if any old parts still exist, or if it was just never installed by GM.
I agree with the guy in the vid, it just creates more clutter in the engine bay and with headers, the tube would be worthless to me. I like all the room I can get while working on my cars. I deleted the AC in my last 4thgen for weight and to make room for big trans cooler+a super sucker ram air but this new car I have will keep that stuff. Last car was a little too extreme having the windows down all the time smelling exhaust. I would have a headache after going on hell rides due to the noise It was a love hate thing. At the same time with the AC deleted it made plug changes so much easier
Notice all the extra room in the engine bay? Also LOUD valvetrain!
https://rumble.com/v10vwi3-april-13-2022.html
All mods are on topic with this thread
That's interesting, and I may look further into this at some point. But the question still seems to remain on what a 3.27 would do to the 1st gear?
Well, PSH....No more 308? That's a deal breaker
To be honest though, I'm a high stall torque converter fan. I would probably just do one of those. I know Circle D makes one but finding people who have done a higher stall in the 10L80 seems impossible right now. Yank doesn't even make them
Here's what a Yank SS3600 did for my 4L60
https://rumble.com/v10vxh3-april-13-2022.html
https://rumble.com/v10vxrn-april-13-2022.html
Really? That's good to know! I stayed away from the A8 due to hearing about shudder problems and such. I really hope this 10L80 will prove to be reliable and solid. I know they are having some issues in the trucks with the idler pully. I almost stayed away from this 2022 Camaro for that reason but here I am
Dynamical is offline   Reply With Quote
Old 07-10-2023, 12:34 PM   #20
Kamero6
Drives: 6th Gen LT1
Having test driven the M6 LT1, I know 1st gear with 9.92 breaks loose if you floor it. 13.0 is too short anyways, unless you run drag tires it will break loose no matter what.
I think 3rd gear with 3.27 would be killer with 7.00 final. Little bit shorter than 2nd manual, and between 2nd and 3rd with 2.77.
4th with 3.27 becomes 3rd with 2.77.
This is interesting to see, I will create a new topic later to debate it.
btw that 4th gen sounds amazing.
Old 07-10-2023, 02:58 PM   #21
Dynamical
Dynamical's Avatar
Transmission and gears is one area I haven't looked into a whole lot. I upgraded from the 3.23 gear to 3.73 with the SS3600 stall (later a 4K stall) because I know it's been a staple in many cars with the 4L60. It was a nice addition to the fully built N/A setup I had. Thanks man I miss that car. If I kept it I would of had an LS3 and at least a 12bolt rear installed. It already had the FLT level 4 4L60. 7 years ago I let it go for WAYYY less than what they are going for today. Kicking myself in the ass!
I'll be interested to read if you make that thread. There's always something more to learn
Old 07-10-2023, 06:39 PM   #22
CHASLT1
I had a new screwed up 2019 C7 from the get go, As soon as i moved the car at the dealer when i bought it i knew something seemed odd. I pushed way down on the gas to even move the car. Slapped a range on it at 150 miles and then shudder and RPM's moving all over the tach and the worst lag ever and then rear end warble. Lemon lawed that POS and then got the 2021 LT1 and what a diff.
I now have a 2015 C7 Z51 A8 that has never been touched and it works like a dream. So beats me why some were bad and a few never had a prob.
Old 07-10-2023, 06:55 PM   #23
Dynamical
Dynamical's Avatar
Well that explains it then. So you got rid of the 2021 LT1? Or you have both cars now? Glad you got it worked out
Old 07-10-2023, 07:02 PM   #24
CHASLT1
I had it for 6 months. I just like the size of the Vettes better.
Old 07-11-2023, 08:15 AM   #25
Hmm, that may well be the case. My A8 is tuned and I don't remember the time too well when it wasn't, but I get a nice 'whaaam' (torque cut) in the 1-2, 2-3 and 3-4 shifts, then 4-5 is quieter (no torque cut, I presume), and I don't think I've had a 5-6 WOT shift as that would happen at ~150 mph... no Autobahn (but state troopers galore) in my neck of the woods, and I'm not fast enough to reach that speed in a 1/4 mile at the dragstrip.
I love on and off ramps, too The Camaro's handling and cornering limits are very far from what you can experience in the street, and even more so once you add power.
Come on now, the car is very-very practical. I can take my wife out and already have fun on the way. She probably gets bored stiff by me pointing out her separate A/C control, the butt cooler, the handy wireless charger and the ambient RGB footwell lighting to her the umpteenth time... but she always plays along, "they're nice, as long as you like them, A/C is enough for me I don't need anything else"
Oh, and I was able to pack 4 max size carry-ons into the trunk, along with a few extra gadgets. Who says this car has no practicality, sheesh
Old 07-11-2023, 06:24 PM   #26
CHASLT1
All my LT1's had that bang shift and never on my 3 C6's.
Old 07-12-2023, 03:56 PM   #27
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Congrats!
Hey all!
After 7 years without a fast toy I finally decided to pick up a 2022 LT1.
My last car was a 2002 Camaro SS H+C+I boltons. Had a 3600-4000 stall, 3.73 gear and some weight reduction. Best 1/4 mile of 10.9@123mph with a 1.5 60'
Very fun street/strip car, loud and obnoxious! I do miss it and wish I never sold it but here I am today with an LT1.
My first impressions of the car...
It is so quiet I cant take it. One reason I got this one is it has the NON-NPP, so it will be easier to pick the full exhaust system I want. But right now it sounds very tame.
The AFM/DOD has GOT to go. At least temporarily I will get a range unless someone can tell me if there's a way to keep it off until I can get a real tune. By the time I want a tune I will probably remove the whole AFM/DOD system and install a cam.
I went WOT a few times and I'm impressed with the quick shifts of this A10. I'm wondering how a higher stall TC would do in this trans. I know Circle D makes them but I cant find anyone who's installed one yet
Congratulations on your new Camaro and welcome to the community! We are excited to see your ride evolve over time!
Sales@Phastek is offline   Reply With Quote
Old 07-12-2023, 04:13 PM   #28
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
I can't say that I hate it, but I am glad I don't have one. When I think back to the 'golden age' of muscle cars when I was still buying cars and modding them rather than just buying a final product I was happy with several things that are relevant to your question come to mind.
Why put a dual exhaust and headers on a V8 that didn't come with that? Because it is a performance enhancing move to allow a car to breath better and sets you up for other performance mods. Why put in a cam - for performance. Why supercharge, - for performance. The changes in exhaust note, cammed idle sounds, supercharger whine, were incidental to improving performance. Those sounds came to be associated with cars that were set up to run, but IMHO the sounds were secondary effects, the primary purpose was performance.
Think about why we like those particular sounds? We associate them with badass cars.
Putting a sound tube on a car does nothing for performance, it just makes the car sound 'better' and only to the occupants. But the 'better' sound was originally a marker of performance.
So to me, sound tubes are fake because they 'sound like' a modded car with a performance exhaust, but they aren't. If I had one, I would remove it.
Wyzz Kydd is offline   Reply With Quote
