Old 07-13-2023, 10:15 AM   #15
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Originally Posted by Wontspeak View Post
Mine.
You can take it to the dealership and hope they are competent and fix your car like they did for Wontspeak.
Originally Posted by bdavies11 View Post
Most likely a grounding issue. Myself and many others had the bouncing tach on hot days, along with the hot start issue. I followed SSDan's guidance a couple years ago at this link https://www.camaro6.com/forums/showthread.php?t=586153 and it fixed both my issues at once. Haven't had a bouncy tach since.
No reason not to give it a shot. It’s quick, easy, cheap and even if it doesn't help the tach, it won't hurt anything.
Or you can follow the link provided and add your own ground cable. Either way a solid engine to body ground will likely fix your problem. I took the easy route and added my own ground cable.
476 rwhp/440 rwtq (sold)
rpm, rpm needle bouncing
