Old 06-19-2023, 11:03 AM   #15
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Shop mechanic said its not likely to be a valve, because when he tried to turn the crank it would not spin forward or backwards.
Old 06-19-2023, 11:07 AM   #16
ctrlz
Based on what I'm reading here, I would suggest pulling the plugs first and looking in each cylinder with an inspection cam.
Old 06-19-2023, 11:11 AM   #17
FlukeSS
FlukeSS's Avatar
I may do that, but right now I have to tow the car back to my house as the shop is not equipped to work on internals "so they say"
Which is fine, take the good with the bad when it comes to modifying a vehicle.
Old 06-19-2023, 12:27 PM   #18
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Fluke, since you are in Michigan I would contact either Katech or Livernois and talk to them about your LT1. I seriously doubt a dealership would touch it since it’s modded and you don’t have a warranty on the engine anymore. Good luck!
Old 06-19-2023, 12:29 PM   #19
FlukeSS
FlukeSS's Avatar
I just called Motorcity Speed - Billy Briggs Racing Engines.
Explained the situation to them, and they said they can take a look and troubleshoot the issue to figure out why the engine locked and at least give me an idea of cost of repair.
Even he said it was odd the engine locked because the mods I have are not anything out of the ordinary.
Old 06-19-2023, 12:43 PM   #20
adamjwilson
Drives: 2022 Camaro 2SS A10
Good luck! Hope everything turns out OK with not too much of a hit on the wallet
(+1 for KaTech- always provided great service to me)
On a lighter note... so who won? you or the other Camaro when you did those pulls?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 06-19-2023, 12:46 PM   #21
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yeah I agree to start with a bore inspection, especially if the rings weren't gapped. If nothing obvious, then a bearing check.
Old 06-19-2023, 12:49 PM   #22
FlukeSS
FlukeSS's Avatar
Just talked to them again, he said chances are its a spun main barring. He said from the manufacturer they come with tight tolerances and when you start adding power they tend to fail.
So if that is the case new engine is the next step I guess.
I told them to troubleshoot and get a confirmation on what caused the lock up. Its worth spending the money to figure out what I should do or consider doing next.
Old 06-19-2023, 12:50 PM   #23
Yang N’ Bang
17’ Hyper Blue 2SS
Yang N’ Bang's Avatar
Drives: 17’ Camaro 2SS
Fingers crossed for you, hopefully wont be too bad.
Yang N’ Bang is offline   Reply With Quote
Old 06-19-2023, 01:00 PM   #24
FlukeSS
FlukeSS's Avatar
I did find this on Engine Builder website regarding a spun barring.
It doesn’t matter what type of bearing is involved, be it aluminum or a babbitt-faced tri-metal, because all types melt start to melt around 450 degrees F or so. A babbitt overlay on a tri-metal bearing offers good seizure resistance, but once it goes away the copper layer underneath lacks seizure resistance. Consequently, if there is enough scuffing, friction and heat due to a lack of lubrication, the bearing will melt, smear and stick to the crank journal. At that point you get a seized or spun bearing with whatever additional damage it causes.
Although this may happen suddenly, often there has been an ongoing lubrication problem that has caused a bearing to scuff, run hot and overheat. This can discolor the crank journal and/or blacken the big end of the rod. So if you tear down an engine and see such signs of overheating, it’s a solid clue that the engine has an oiling issue that needs to be identified and corrected before it’s put back together.
To be fair, I don't recall ever seeing an oil pressure issue nor indications of it prior to the issue happening.
From what this describes its something that happens over time not just instantly.
I never had an excessive amount of coolant temp, or oil pressure indicator issues.
Hoping it might be some sign of good news not to be a spun barring, as I very much would prefer it not be that.
Old 06-19-2023, 01:17 PM   #25
Katech_Mike
Drives: 2015 Camaro ZL1
Simply cutting open the oil filter will reveal if the engine spun a bearing.
Katech_Mike is offline   Reply With Quote
Old 06-19-2023, 01:42 PM   #26
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
What a bummer. Hope it isn't too expensive.
Wyzz Kydd is offline   Reply With Quote
Old 06-19-2023, 01:45 PM   #27
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
That’s good advice and at least you will get an answer right away if you see metal specs.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 06-19-2023, 01:51 PM   #28
Johnfin
Drives: 2018 ss
Is this a 2020 2SS that bit the dust?
Johnfin is offline   Reply With Quote
