Old 07-23-2023, 09:35 PM   #15
50MileSmile
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
Originally Posted by NicKey View Post
If you are that concerned about the MFG warranty, then I wouldn't use any fuel or fuel additives which might tend to void it. You car is designed to run on 91 via the low octane table. Running your car hard on 91 in 105 ambient could hurt your engine and at best it will be down a bunch of power.
About the best you can do without taking a chance on violating the warranty is to use Top Tier gasolines, which many auto manufacturers recommend: https://www.toptiergas.com.
50MileSmile is offline   Reply With Quote
Old 07-23-2023, 09:44 PM   #16
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Thank you NicKey for you response, I don't DD the Car , I did run 3 of the 8 Summit ET Racing Series, temps were 70 to 85 in Match / April , now with temperatures above 110 plus the last month , I don't take her out , tho I did about 3 weeks ago early morning cruse in the Desert , temperature was around 90 . Since the 2 dates at the Track , I haven't run her hard .
Question normal driving 105 degrees nothing prolonged spirited (as they say here) with an occasional launch in 1st thru 2nd considered hard ?
I'm learning Thank you again for your patience and response.
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
