06-05-2023, 12:28 PM | #15 |
You might be lucky. If your tune happened before the code had a chance to set, you’re good anyway.
06-05-2023, 05:14 PM | #16 |
Drives: '16 2SS M6 Join Date: Aug 2019
When done correctly, the code is turned to "do not report", therefore it won't even show up on the scanner. I have an original MPVI and running 4.4.4 so I still have access to that area. There are many tuners that have kept multiple versions on their computer so they can still do it.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
06-06-2023, 09:36 AM | #17 |
Drives: 22 2SS 1LE Join Date: Mar 2022
Idk why everyone keeps parroting that you cannot disable emissions codes with latest hp tuners. It is not true. They just make you jump through an extra hoop to access them.
22 SS 1LE M6 - MSD intake, NW103 throttle body, Roto-Fab, HP tuned by me.
438 whp 411 wtq -SAE- pump gas on mustang dyno. |
06-06-2023, 03:31 PM | #18 |
Drives: 2022 1SS 1LE Join Date: Nov 2021
space your 02 sensors away from the bungs they are in. Spark plug non-foulers work for this. I've done it in the past on other cars and it worked. Not saying it's the best solution, but an option to consider.
2022 Shadow Gray Metallic 1SS 1LE A10 Rotofab Dry ST delete.
06-06-2023, 04:26 PM | #19 | |
06-06-2023, 05:02 PM | #20 | |
A ‘16 is different. Different ECM (E92) and you can do the “Write Entire” flash to overwrite the code as you alluded to.
06-06-2023, 05:04 PM | #21 |
And you’ve accepted liability. When the EPA comes knocking, HP Tuners will undoubtedly be sharing that info.
06-06-2023, 05:33 PM | #22 |
Yep
06-08-2023, 01:21 PM | #23 | |
David
07-31-2023, 10:48 PM | #24 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
Just an update after spending a lot on different anti foulers and 02 simulators I still get P0296. I’m guessing there is no fix for this period unless I get green cats. Is there really no one here who got long tubes after all the Tuners banned turning off the sensors?
07-31-2023, 11:35 PM | #25 | |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
Um ok. So these codes can easily be unchecked in the tune with HPT. You need parameter access, so anyone that takes the 10 minute free online training can get the cert to be able to unlock all those grayed out options now.
Then you just go into the tune and disable those two codes. Once you flash over, clear the DTCs and its gone. Here's a video from GRG to show you how to get the access to those options. Its nothing to do. |
