Old 06-04-2023, 09:04 AM   #15
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
2018 SS no shutter ran a 11.87@117mph last week on street tires and a 20mph head wind. GPI tuned/trans tune E85,LT2 intake, Roto fab CAI, Soler throttle body stock ported.
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 06-05-2023, 01:36 AM   #16
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
At 30,000+ mine started the shudder, changed the fluid and filter myself, no issues since.
Glenn
SOLD - 2017 Camaro 2LT RS Convertible
2017 GMC Arcadia Denali
truckrglenn is offline   Reply With Quote
Old 06-05-2023, 10:21 AM   #17
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
2016 2SS bought in Dec '19 with 1880 miles. Didn't shudder. Had the TSB done at a Chevy dealer in '20 as a preventive measure. Now 7700 miles no issues.
Wife has a '16 CTS AWD 2.0T. It started the shudder at 41k and I took it to Caddy immediately. TSB done and no issues since.
A lot depends on how quickly the owner did the TSB after the shudder appeared, and when it did (year). They didn't figure out the absolute fix until '18 with TSB 18-NA-355.
I advise all my friends with this A8, or ones considering buying a used A8 car to have it done even if they have to pay OOP for it, regardless of whether it's exhibiting the symptoms.
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 06-05-2023, 11:36 AM   #18
BluinSC
Drives: BVM 1SS
71k miles not problem with the trans. Had to replace the rear diff in December though.
BluinSC is offline   Reply With Quote
Old 06-05-2023, 12:57 PM   #19
This is great advice Just one minor addition, the "absolute fix" fluid was made available in late January 2019, so any trans flush, single or triple, received prior to that and/or with previous fluid iterations is unfortunately irrelevant and has to be repeated.
Old 06-05-2023, 02:04 PM   #20
ctrlz
Originally Posted by CHASLT1 View Post
I wonder if anyone really knows what the real prob was with the A8?
Pretty well documented. the fluid used in pre-2019 A8's basically had the wrong chemistry. it attracted water, which led to irregular lubrication of clutches in the torque converter, causing them to chatter and wear irregularly. This situation was reversible if the bad fluid was replaced soon enough.
The reason for different experiences is probably related to things like usage patterns, humidity, etc. I do not think cars with the newer fluid had shudder, which implies that GM's theory for the failure was correct.
Old 06-05-2023, 05:50 PM   #21
CHASLT1
Drives: 2021 Camaro LT1
Still odd that some A8's never had a prob and some did.
CHASLT1 is offline   Reply With Quote
Old 06-05-2023, 08:45 PM   #22
ctrlz already said it, usage patterns, humidity, plus temperature and mileage all make a difference—in other words, unless preventive or corrective action is taken, most likely all A8s would/will be subject to the shudder eventually.
Old 06-06-2023, 05:43 AM   #23
CHASLT1
Well maybe i should do the triple flush on my C7. Sure it won't be cheap. This car has no service history other than the normal oil changes and one trans service.
Old 06-06-2023, 05:51 AM   #24
ctrlz
Same situation apparently. Lots of similar posts on corvette forums.
https://www.corvettecare.com/never-h...d-this-good-5/
Old 06-06-2023, 07:21 AM   #25
xmattyx
mattyv
xmattyx's Avatar
Drives: 2017 Camaro 2SS
bought my 17 with 9k miles on it, had the flush done right away, no issues since, prob because the mileage was so low.
2017 Chevrolet Camaro 2SS
2017 Jeep Grand Cherokee
2015 Jeep Compass (sold)
2014 Hyundai Sonata GLS (sold)
2013 Chevrolet Camaro 2LT/RS (sold)
2013 Hyundai Genesis Coupe 2.0T (sold)
2010 Chevrolet Camaro 1LT (sold)
2007 Dodge Charger SRT-8 (sold)
2007 Cadillac CTS (sold)
2005 Chrysler Sebring (sold)
1998 Dodge Avenger (sold)
1992 Mercury Topaz (sold)
xmattyx is offline   Reply With Quote
Old 06-06-2023, 05:54 PM   #26
CHASLT1
Odd that my 2019 C7 had the shudder at 400 miles and put a Range on it at 150 miles. I got the range on my 2015 C7.
Old 06-06-2023, 06:39 PM   #27
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Range didn’t guarantee much in my opinion. While keeping it out of AFM mode does reduce commanded slippage in the TCM, the TCC tables still have some slip commanded even outside of AFM mode.
Old 06-06-2023, 06:46 PM   #28
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Mine had the issue when the original owner had it. He had it flushed twice. It's now just about 50k and no issues.
jamala00 is offline   Reply With Quote
