Old 12-25-2023, 09:44 AM   #15
t-ray
Drives: 2022 2SS 1LE
For those that use the XGPS-160, where do you mount it? I've seen people mount it on the dash and I've seen it mounted on the trunk forward of the spoiler. How is it powered / does it require a power source? If it is battery powered how long does it last?
2022 2SS 1LE - no 1/4 time
2018 1SS 1LE - no 1/4 time
2011 Mustang GT brembo - 12.17@114 bone stock+drag radials
2005 G35 Sedan 6MT - 13.1@104pm fbo+drag radials
t-ray is offline   Reply With Quote
Old 12-25-2023, 03:07 PM   #16
cdb95z28
cdb95z28's Avatar
My Dual XGPS160 Skypro GPS came with a sticky/friction mounting base. I just put it on the dash and it stays put, even when running 3Rs. It has a battery. I charge it before each track day and it has had enough capacity to run all day without recharge.
"KEEP THE FAITH"-Fbodfather
Old 12-25-2023, 10:34 PM   #17
Badmojo
aka BeastZL1
Badmojo's Avatar
Garmin Catalyst unless you want to do serious data analysis.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 12-26-2023, 08:51 AM   #18
BoilerUP
BoilerUP's Avatar
Drives: Cadillac ATS-V
I velcro'd mine to the rear deck center speaker of my ATS-V so it has an unobstructed view of the sky. Stays put 100%, connects quickly, A++ would recommend.
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber*Pitt Race*VIR
BoilerUP is offline   Reply With Quote
Old 02-02-2024, 12:12 AM   #19
sab123
Drives: 2022 Camaro SS 1LE
My experience with a GPS receiver (in a much older MaqQData data acquisition system) is that if you want to see the accurate lateral g-forces, you need to mount it around the center of the car, probably on the roof. When mounted on the dash (as I do), it will show the higher g-forces, because there are higher transient accelerations on this part of the car, especially in the tight turns. And the farther form the center it is, the higher g's you will see. But for relative evaluations it doesn't matter much, and mounting on dashboard is more convenient.
sab123 is offline   Reply With Quote
