Old 05-10-2023, 07:52 PM   #15
ste6000
ste6000's Avatar
Drives: 2018 Camaro SS
Originally Posted by wang970305 View Post
I’ve seen couple YouTuber drill a hole on the air intake then connect a tube to the cab? For a louder whining. I’m like what the heck
yeah the SS camaros had that for piping engine noise in. funny SS people take that out and youtubers with zl1s are trying to put that in.
2018 Camaro SS - Hyper Metallic Blue
ste6000 is offline   Reply With Quote
Old 05-16-2023, 11:19 PM   #16
TheSixSpeed
TheSixSpeed's Avatar
Drives: Chevrolet Camaro LT1 6 speed
If you’re looking for the most cost effective way to get a distinctive whine, your best option is to do a LT1 to LT4 conversion, and then throw on a different supercharger lid.
Here’s a link to a conversion kit, and a link to a replacement supercharger lid.
Here’s a sound comparison video.
Alternatively, you can do this with Magnuson 2650.
Current mods: Kooks 1 7/8” long tube headers, DSX flex fuel kit, Dragonfire spark plug wires, Rotofab dry CAI, Hurst shifter, Weld wheels, tuned by Exodus Performance
TheSixSpeed is offline   Reply With Quote
Old 05-17-2023, 08:35 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by Jus Cruisin View Post
If i was to add a supercharger to a car, I would go procharger. Easier to install and must be more efficient because the fast doorslammers are running them over screw blowers.
Lol so we should base our purchase for a streetcar off of what Promod's are doing at NMCA and NPK races? Those cars are running direct drive head units bolted directly to the crank. Not even remotely close to the entry level P, D, and F series Procharger kits for street cars. The entry level Prochargers are not better than a PD in any metric other than they "might" be a little easier to install. There is a reason why OEM's use PD superchargers and not Centrifugal for production vehicles.
Either way Prochargers don't whine...it's more of a whistle with gear noise added in.
The only supercharger that will get close to a Hellcat level of whine is a ported LT4 with aftermarket lid. Or a 2650 with DSX lid but you will not get much whine from a 2650 only spinning hard enough to make 9-10psi to keep it safe for stock LT1 internals.
So if you want Hellcat level of whine, then you need to upgrade rods, pistons, and fuel system to support a ported LT4 supercharger pullied to make 15-16psi of boost. A lot of the blower whine is due to how hard the unit is being spun(blower rpm).
Honestly the OP would be better off trading up to a ZL1.
Old 05-17-2023, 09:20 AM   #18
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
The Foster sound tube mod on the ZL1 works as advertised. When your WOT and high RPMS that thing screams. Just not sure you can here it outside the car. It does take some tuning on the cabin side of the inlet, it's covered and how much it's covered or with what materials you can get a whole lot of just intake WOOOOOSH, with the whine.
Old 05-17-2023, 06:48 PM   #19
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I don't think anyone makes a kit, but a gilmer cog belt drive does the trick on pretty much anything, supercharged or not.
https://youtu.be/dw6BSa_5_5w
https://youtu.be/X_9v_H4j_Pk
Mods being installed-
Old 05-18-2023, 08:27 AM   #20
Sillysspeed
Drives: 22 LT1
Zl1 time! Kong X port on the blower and supporting bolt ons and you should have all the whine you want. Hopefully you like convertibles or sunroofs cause that seems to be all that’s available right now with zl1’s. New atleast
Sillysspeed is offline   Reply With Quote
