Old 05-19-2023, 06:30 PM   #15
6spdhyperblue
Drives: 2SS 1LE
Do you know if a katech port job would produce similar results
Old 05-22-2023, 11:58 AM   #16
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
I don't know. Brett has posted his flow charts a couple of times. You could compare Katechs flow #s and see. Flow bench numbers will give you a pretty good idea of how the two heads will stack up against each other.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 05-22-2023, 08:37 PM   #17
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
They look pretty similar but here is Katech. I have these on mines and they flow pretty good.
https://katechengines.com/i-30498128...der-heads.html
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 05-22-2023, 08:40 PM   #18
s346k
s346k's Avatar
Drives: like an old lady
i wonder what caused the valve train failure on the pray ported head. something aside from the normal abuse seen by the na sbe crowd?
Old 10-18-2023, 10:55 PM   #19
savyomix
Drives: 2017 Chevrolet Camaro 1SS
Originally Posted by Sillysspeed View Post
Are the stock lt1 valves hollow stem or standard stainless steel valves. Good gains btw
I believe they're hollow which is also why it's common for people who put Aftermarket cams with a higher RPM range drop oem valves since heat and hollow spaces dont really mix well together.
savyomix is offline   Reply With Quote
Old 10-19-2023, 04:13 PM   #20
oldman
Drives: SS 6 speed of course
I love Pray's stuff, I will go to a High Ram on my next engine. I went to Manley ProFlows with undercut head on my cam change, and there was a noticeable improvement of midrange and top end, granted it was two changes (cam and undercut valves); that said the 2nd cam had lower lift and gentler ramps but longer duration so it was expected to produce about the same HP as my .660 lift cam but last longer and have a stronger loop.
