Old 04-28-2023, 05:34 AM   #15
mbar
Drives: 2016 1SS
Originally Posted by JamesNoBrakes View Post
I have a hard time believing sintered is going to last longer. I use them for DH racing and long descents down 50% grades, but rotor heat capacity is a huge deal there too. Its the extended braking where these both shine, but they eat the rotors faster too. They dont glaze like organics, but I have my doubts here, theres always a tradeoff.
Good point. When I spoke over the phone with EBC , they told me that the hardest part converting sintered technology from bike to car use was controlling the rotor wear. It took them several years to develop these pads because at the beginning the rotor wear was substantial.
As noted above, so far after 3 days I got 0.2mm rotor wear, which I think is acceptable considering we have 2mm until we get to minimum thickness.
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 04-28-2023, 05:40 AM   #16
mbar
Drives: 2016 1SS
Originally Posted by DaveC113 View Post
Any comments on how these work cold? Right now I switch between 3.12 and OEM for street and autox use and wonder if the EBCs could possibly do both? Quote from EBC site:
They work very well from cold. I drove them for a week before my track event. However, I can’t tell what would be the rotor wear if I keep them in all the time. With many track pads that used for DD, rotor wear is accelerated.
Old 04-28-2023, 11:58 AM   #17
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I think longer term will be interesting to watch.
I got more aggressive Hawks and the lack of power initially/before heat is noticeable. Not to a dangerous point, but definitely noticeable, as is the stronger bite when warm.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 04-28-2023, 12:46 PM   #18
23Redrocket
Drives: Chevy Blazer, Corvette, Camaro
I ran EBC Blue stuff pads on my Z51 vette on both track and street. No issues, however the vette is a little lighter. Went from a 2 min lap to 1:42 at PIR by just switching pads. Very little dust compared to stock and incredible stopping power. This was on stock rotors also.
Just my 2 cents.
23Redrocket is offline   Reply With Quote
Old 05-01-2023, 06:04 PM   #19
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
I just notices the price, that's even lower than Hawks!
https://knsbrakes.com/products/car/5...ms/series/1089
Follow up question: How is the noise on the street? I ask becasue I typically swap in Hawk DTC60s in the spring, do 4-5 track days through the spring/summer/early fall, and then swap back. The Hawk give me good fade resistance/torque and fairly long life with very little daily noise. Just a bit at the very end of stop. I ended up getting 8 track days on a set of Hawks.
I need the same to hold true if I switch.
5.M0NSTER is offline   Reply With Quote
Old 05-01-2023, 06:16 PM   #20
mbar
Drives: 2016 1SS
The DD noise is ok. You can hear a mild squeal during the final stop, but nothing that will turn heads in the street.
Old 05-02-2023, 03:32 PM   #21
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Originally Posted by mbar View Post
Judder from hot spotting the rotor / pad deposit
Just curious but when you get brake judder after your multiple track days do you just replace the rotor or do you try honing them?
m6-lt1 is offline   Reply With Quote
Old 05-02-2023, 05:09 PM   #22
mbar
Drives: 2016 1SS
All of the above. First I try to run hard with track pads at the street. Hoping it will scrap off any material on them. Honing with a drill attachment tool sometimes helps. If all fails and the rotor has enough thickness left, you can try a shop that will turn them. If they know what they are doing , you will only lose 0.2-0.3 mm of thickness.
Old 05-02-2023, 08:40 PM   #23
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
The Aamco machine at my work can't do rotors this big. The on-car Trucut machine might.
'18 1SS 1LE Black, PDR
Old 08-29-2024, 09:21 AM   #24
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
It’s mid 2024. Will need pads soon. What’s the latest update on performance?
Dabjbr is offline   Reply With Quote
Old 09-05-2024, 04:03 PM   #25
cdrptrks
cdrptrks's Avatar
I tried the EBC SR11 pads at NOLA on Goodyear Supercar 3R 100tw tires but only for part of 1 session. Unfortunately I might not drive my car on track again until next year and it wasn't enough time to fully evaluate the pads but they seemed to have less pedal travel before activating ABS but not like an on/off switch. I think it will take some time to get used to them having driven on stock pads for years but I do want to try. I'm concerned it might be challenging to use them with the stock Goodyear Supercar 3 220tw tires without unwanted ABS since the modulation window seems narrower. I haven't tried them on those tires yet but I plan to.
I put temperature stickers on my stock SS 1LE calipers and all 4 were 250°F max or less with stock SC3 220tw tires and stock brake pads vs. 390°F max front and 350°F max rear with the EBC SR11 pads on 100tw 3R tires and ambient temperature was only around 70°F if I remember correctly. For front brake cooling I have the SS track plastic air cooling deflectors and smaller metal shields behind the rotors. Rear brake cooling is stock aka not much airflow.
Old 09-05-2024, 04:49 PM   #26
FactoryMatt
FactoryMatt's Avatar
Drives: '22 2SS 1LE
you're faster than me, but no issues with the SR11s for me so far. zero fade, good friction. only place i'm getting ABS is a little before turn 7 sonoma in the chop at the crest occasionally. good bias F/R good wear. rotors holding up okay. could use a little more bite coming into 4 and 11, but it's manageable, and given all the rest, as an endurance pad, more than acceptable.
FactoryMatt is offline   Reply With Quote
Old 09-05-2024, 04:59 PM   #27
cdrptrks
cdrptrks's Avatar
@FactoryMatt, What tires are you running?
Old 09-05-2024, 05:18 PM   #28
FactoryMatt
Drives: '22 2SS 1LE
Conti ECF 295/315-19. 37/36 hot. -3.4/-2.3 camber
Castrol SRF and BW ducts
