Old 04-19-2023, 08:08 PM   #15
Sillysspeed
Drives: 22 LT1
First mods to these cars should be catch can and expansion tank
Sillysspeed is offline   Reply With Quote
Old 04-19-2023, 08:37 PM   #16
Greg83
Drives: 2023 ZL1 M6 Sharkskin
"Negative" pressure is (partial) vacuum, this is normal while the car is running with the supercharger bypassed (for fuel economy), the pistons create a vacuum that then helps suck in air via the intake, this is how all naturally aspirated engines work. Once the supercharger kicks in (when you give it some gas), it will immediately build boost, and on your LT4 you should see 9.7 to 10.2 psi.
Bleeding the intercooler circuit is a no brainer, make sure you get it done, as others already stated above. Unfortunately GM did not add a supercharger coolant tank from the factory, so you're at the mercy of whoever assembled the engine and filled the fluids to have done it properly, the only way you as an owner could check is opening up the S/C coolant loop.
I'd say let the dealer do it under warranty, and you make sure they know what they're doing, don't hesitate to go to a different service department if you see anything suspicious.
I’ll definitely try that after the fresh gas. Thank you!!!
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD
2023 Red Hot ZLE M6 ordered 5/9/23, never built
2022 Shadow Grey 1SS-1LE M6-SOLD
2023 Sharkskin regular ZL1 M6-SOLD
Greg83 is offline   Reply With Quote
Old 04-19-2023, 08:38 PM   #17
Greg83
Originally Posted by FrostZ View Post
arpad_m hit the head on the nail, LT4 blower has a vacuum bypass on the blower that is open at idle and cruising as soon as you lean into the blower creates boost closing the bypass and allowing boost to ramp up. Max boost I see is 9-10 maybe 11 PSI depending how dense the air is but that's based on the rather simple gauge.
Thanks!
Old 04-20-2023, 08:06 AM   #18
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I can't confirm this, but I THOUGHT I read the bypass valve was controlled by the ECM on the newer cars. I don't know if that's true (I think there is some merit to it, but I'm getting to that), but I know on my '20, there is a set screw that adjusts the bypass valve in the blower, and by adjusting that to close all the way gave me a little more boost pressure. I believe there are still pressure limits the ECM uses to influence the OEM bypass valve, but all I'm saying is that a lot of people before me made sure their valves were adjusted such that they closed all the way, because they picked up boost/power if they were not.
'20 ZL1 Black "Fury"
Old 04-20-2023, 08:23 AM   #19
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
If you need to with that tank of bad gas or god forbid they filled it with 87 octane, dump in a bottle of booster and top it up with 93.
When I picked up my car my salesman took me right over to the 93 pump at the station.
I checked my bypass and it appeared to be set up correctly but I'd swear I've seen on this fourm a pic of two and you can tell that it's open or not set up correctly.
I had removed that sound plate off the lid and with that opended up you can see the butterfly and easily set that up, if you need to.
Old 04-20-2023, 12:30 PM   #20
Greg83
Thanks guys! Lots of good info. I did a little research and it looks like my coolant tank is a little low so I will top that off and bleed the supercharger system. I assume that system is under more pressure the hotter it is? Should I bleed it while the engine/coolant/SC temps are cool (like you would with a regular cooling system) or should I do it when the car is warmed up or even hot to create the pressure to bleed/burp the system?
Old 04-20-2023, 12:39 PM   #21
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Doesn't really matter when you bleed it. What matters most is all the air being out of the system. Whenever the intercooler pump sees air it stops. You want to make sure that there is constant coolant flowing to the pump and no air pockets
Nimair.ZL1 is offline   Reply With Quote
Old 04-20-2023, 01:09 PM   #22
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
There is no tank on the S/C loop, the clear dual tank on the left is for the radiator.
Mods being installed-
Old 04-20-2023, 01:25 PM   #23
Vigilante375
Drives: 2018 Camaro ZL1
As mentioned, the tank on the passenger side of the engine bay is the coolant for the radiator. The top portion should be nearly full and the bottom portion needs to be about halfway. Both sections have a fill line.
The ZL1 has no factory tank for the supercharger coolant.
There is a method to bleed the supercharger intercooler and if you search YouTube (or on here) for ZL1 supercharger bleeding, you'll find methods that will work. I would recommend buying an actual reservoir from a vendor so that you'll never have to worry about air being in the system as it'll get the air out for you while you drive.
I have an ADM reservoir and have had 0 problems with it. But there are a handful out there to choose from but I think this one is the most simple and not that big while being very easy to install.
Old 04-20-2023, 02:55 PM   #24
Greg83
Awesome. Thanks guys!!
Old 04-20-2023, 05:17 PM   #25
Xelor
Drives: 2022 ZL1
I would go do some 50 to 120 pulls on the freeway. See how it runs. I never followed the 500 mile break in. I ran it hard from the Dealership Day 1.
Xelor is offline   Reply With Quote
Old 04-20-2023, 07:23 PM   #26
DangerZL1
Drives: 2023 Black ZL1 Auto
Display the boost gauge on the instrument cluster jut to see how much boost it’s making if you haven’t already checked
Old 04-20-2023, 10:50 PM   #27
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
150 miles? Dealer filled my car with regular. Might be that simple.
wakespeak is offline   Reply With Quote
Old 04-21-2023, 09:05 AM   #28
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Originally Posted by Idaho2018GTPremium View Post
Some misinformation in these responses. First, the ZL1 doesn’t limit power below 500 miles. 2nd, the comment about “being in the power band” is inaccurate as well. The LT4 makes peak torque below 4K rpm, and in a given gear, THAT is what you feel. So it should feel strong at 3500 rpm in 3rd gear, for example. In 3rd gear the car pulls harder at 3600-4000 rpm than it does at 6000 rpm. So if it feels like an SS, something isn’t right. I second (or third?) the s/c coolant air bleed. It’s pretty easy to do on your own and can be done at home, and you don’t need a custom tool like some will claim. Or you could risk it at the dealer. Make sure the s/c coolant reservoir is full as well.
3rd: the LT4 runs fine on 91, not ideal, but it still makes a lot of torque. That’s all there is in a huge part of the country.
There isn't a S/C coolant reservoir from the factory.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
