#15 |
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
At this point, adding port injection and running ethanol seems to be the way to go on a FI car. Then you don't even have to fool with upgrading to LT4 fueling.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
#16 |
![]() Drives: 2022 Camaro 2SS 1LE Join Date: Sep 2013
Not to get side tracked from my original post but would an LT4 supercharger change anything instead of a ProCharger?
#17 |
![]() Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Yes... your choice on the E85 kit (a few manufacturers out there) I personally have the DSX E85 kit- the flex fuel kit will be needed to run E85 or any blend of E.
As for the LT4 fueling (if needed for your current HP goals).... LT4 high pressure fuel pump (currently there is a nationwide shortage (go figure) so there are some crazy marked up prices on those at the moment.) LT4 injectors will be needed at some point- your current injectors should handle the 500whp but the set of 8 of LT4 injectors is not crazily expensive to get ATM... your current LP fuel pump in the tank should be good to go with your goal. DSX Tuning has these items but will B/O the LT4 high pressure fuel pump. Do a google search for the best prices as it has been a while since I got mine.
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
#18 | |
#19 |
Could just go with the MSD manifold instead of running plates. LT4 stuff isn't cheap and he would have more headroom in the future, we all say the next part is the last one and we're just going to enjoy the car. Plus with port injection you'll have fuel cleaning the intake valves.
#20 | |
I've never run ethanol on anything before, how does that affect the performace? |
#21 |
The LT1 engine LOVE E fuel... I normally run a blend 50% E85 and 50% 93 octane. You will see a HP boost running E for sure. King or CP can correct me if I am wrong here, but I think it is like a 25-45 HP gain over 93. MPG will suffer but the HP gains..
The easiest mods are a cold air intake, E85 kit, maybe aftermarket exhaust (Corsa or Borla), and a tune. You will need a tune after installing the E85 kit. Normally tuning your ECM will void your powertrain warranty, so if this is a concern, ask you local dealer to be sure. I have seen it both ways here. I voided my powertrain warranty long time ago with about 200 miles on the car...lol.
#22 | |
I do see port injection in my future though with drilling the rails on the Whipple, but that is next year at best. MSD is a cheaper option for sure.
#23 | |
#24 |
No if you install the MSD then you plumb the manifold for port injection as a fuel system upgrade. Either way you go the fuel system needs upgraded in order to run boost and especially any amount of Ethanol. The problem is DI fuel upgrades (LT4 fueling for example) have skyrocketed in the last 6 months which makes port injection a much more attractive option.
#25 |
Thank you to everyone for the great advise! After much soul searching and personal reflection, I have decided to wait on a super charger or any mods that require a tune that could void my warranty. Being this car is my daily driver, I would really like to keep my warranty in tact as long as possible. So for the time being I think I will just keep it stock and add an axle back exhaust for better sound!
Again thank you everyone for the advise and education! |
#26 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
Mastmotorsports.com also has an LT2 fitted for port with rails for a very reasonable price. When I called they said they had not been pressure tested for high boost such as 12-22 but are great for low boost.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror ![]() |
#27 |
@Jstanton- you have alot of advice here... you have provided us your HP goals (500-550 HP) but what is your budget? Alot of what you wanting depends on a budget you have for these mods... you will need to advise the forum here
But if you want to leave your warranty intact... then keep the car STOCK. Most/All the mods you are wanting will void the warranty after the required tune.
#28 | |
| Tags |
| 1le, boost, procharger, super charger, supercharger |
