#15 | |
I assume when you say 29 degrees for LT1 that is NA which seems right. Just curious what kind of timing do you run for FI LT1's on E?
#16 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Boosted LT1's I am very conservative on timing. Like 15-16 degrees on 93 and 19-20 on E even though I feel like you could get away with 21-22. I don't do much of the boosted LT1 stuff honestly because the pistons are so weak so I am definitely not as knowledgeable here. Even with a conservative tune these things can pop and then the tuner gets blamed. I actually turn down most work if it involves a boosted LT1 with stock pistons. |
#17 | |
#18 |
Snackbar Tuning
What do you guys think about Lambda on E60-E70? Meaning, do any of you run leaner on E60+ than you would tune a customer car for?
#19 |
I run my LT1 .82-.83. I try to keep LT4 stuff around .84-.85.
#20 |
Snackbar Tuning
Same here. I've gone up to .86 on my LT4 without an issue on 14lbs but I moved it back to .84-.85. I get nervous about .86.
Clients LT4's I target .83-.84 unless a lot of blower/psi and meth. Then I target richer. |
#21 |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
#22 |
Snackbar Tuning
As a generality, typically larger cams need more timing in the lower RPM range since dynamic compression and/or efficiency is reduced vs the factory cam in that lower operating ranges. As for WOT timing, it all depends on the build. A bigger cam doesn't automatically mean it requires more timing at WOT. This is where it is beneficial to use a dyno to determine what timing the setup likes.
#23 |
^Agreed
