#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
UPDATE Black Wing Brake Ducts
So I went to a dealer car advertisement and used the VIN associated with that listing. Let's see if this works better (LOL).
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#16 |
![]() Drives: 2021 SS 1LE Join Date: Mar 2023
FWIW - I have a pair on order from one of the online vendors (Trummers I think).. Order went in about 2 1/2 weeks ago and as of yesterday expect to ship in "2-3 days" . .
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
I don't understand why people are so willing to pay money for huge engine power but then doing everything they can to avoid spending money on the proper brake kit. Spend the money on a proper brake kit and you won't have to worry about melting dust boots, you will have much thicker brake pads to start with, and much better rotors from a cooling standpoint. Once you have an Essex/AP kit you just put the parts on and go. No more fiddling around with brake problems. Not to mention you will save probably 6-8 lbs per corner at the front with an Essex/AP kit.
#18 | |
#19 | |
Greg
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 03-29-2023 at 02:45 PM. |
#20 | |
I think if you made the investment in an Essex/AP kit you will wonder why you didn't do it sooner and could have avoided messing with band-aide fixes on the stock Brembo system. The stock system is very good for a street car. But with your power level and running slicks...they were never designed for that kind of abuse. If you try the Ferodo pads from Essex you can switch to the DS2500 for street driving and use the DS1.11 or DS3.12 for track use and not have to worry about burnishing the pads each time. The Ferodo pads use the same base materials so you don't need to burnish pads when switching between the Ferodo compounds. I used the Essex/AP kit on my 5th gen 1LE and used the Ferodo compounds and was very happy with them. I now use Essex/AP brakes on my C6Z06 (550 RWHP) and the brakes have been the one part of the car I have not had to tinker with. Just install and drive! If you look around there are nice condition used kits that come up for sale once in a while. GLW your brake remedy decision. I already know what I would do.
#21 | |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#22 |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I've swapped the track SS 1LE air deflectors onto my ZLE last season and now have the blackwing deflectors sitting on my tool box waiting to get installed. I badly want a real duct kit like the 1st post has listed but I'll see of the blackwing ducts act any better this season
#23 |
Black Wing Brake Ducts Installed with PICS
Ok Tonights project was to install these BLACK WING brake ducts. The FIRST shows the STANDARD SS brake duct that was on the car. The SECOND pic compares the size of the STANDARD brake duct to the BLACK WING brake duct. The third pic show black wind duct installed on PASSENGER side and the LAST Pic shows the Black Wing duct installed on the DRIVERS side. Notice that I put some protective covering over the wheel speed sensor wires so that they would not be chaffed if they came in contact with the brake duct.
AFTER I came up with a legitimate BLACK WING Vin Number, I got these within about two weeks. They have a little scoop on them that hangs a little lower than the bottom of the car that collects up more air. Once I go to the track this weekend I will take some TEMP readings to see if these are really effective or not. Theoretically to get the MOST benefit you want to remove the backing plates that protect the BACK of the rotor but that is probably NOT a good idea on a daily driver.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 04-12-2023 at 10:55 PM. |
#24 |
Glad you got them so fast!
#25 |
Well really I ordered them 6 weeks ago and there really wasnt any movement by GM to fill that order until we gave them a BLACK WING VIN about TWO weeks ago.
Apparently GM gives a higher priority for any backorder part that is tied specifically to a VIN.
