#15 |
Moderator
You’ll need to do a rear brake conversion like I did to run 15’s. BMR sells the kit.
#16 |
![]() Drives: Chevrolet Camaro Join Date: Jul 2022
Well, I ordered the 555ii in December and still have no ETA, so I am about to try something different I guess. 305/30-20 is what I ordered. I might just go with 305/35-20.
#17 |
305/35/20 is what I run. Per Dragy, Car will pull 3.0 0-60(2.7 with 1ft roll out like C8 uses) launching from second gear. So they won't hold 700+whp hammering it from a dig on the street but they do pretty good. They should hook really good on a basically stock ZL1.
#18 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#19 |
For your car I would try the Toyo RR.
#20 |
This is the first time I've heard of this tire. It's a bit taller than the R888R and doesn't have a noise-making tread pattern. I'll check availability. (It too is not currently available. Appears to be a summer racing tire.)
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 03-11-2023 at 11:51 AM. |
#21 |
That is what my Brother runs on his Z06 M7 that 60-130's mid 4's.
#22 | |
#23 |
#24 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
you need to do what I did and go 555RII 345/30R19, they are available
#25 |
I run the matching 245-40-20 Nitto 555G2 with my 305-35-20 R2s in the rear
#26 |
Summit now has them. Your power is close to mine, so tell us about them.
2020 ZL1LE A10.
#27 |
#28 | |
Once you get them up to temp they are good, you can run them at ~30 psi and drive them around like street tires and definitely hold 3rd at our power level, if its a nice warm day you will hold 2nd. If you drop them down into the mid/high teens they behave like a drag tire. I run PS4S 305/30R19 in the front and 555RII 345/30R19 in the rear
