#15 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
#16 |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
I used to have it aligned all the time at Goodyear, but when I found out about the mandatory bolt replacement, I had the alignment done at the dealer. It has stayed aligned for 8K miles now.
#17 |
On a stock car, there are 4 bolts up front that need replacing. Those are the bolts at the bottom of the strut. In back, you need two control arm bolts that adjust the camber, and the two toe rod bolts for...toe.
#18 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
According to the linked post earlier in this thread, it's only the bolts in the rear that need replacing. The front strut-to-knuckle bolts are not designed to yield.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#19 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
You track your car? Daily driver? What alignment are you having them do? Track or OEM spec?
#20 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The front strut to knuckle bolts can reach a point of yield if they are overtightened. That is why any important fastener should be tightened to its spec.
"KEEP THE FAITH"-Fbodfather |
#21 |
With all that being said about the one time use rear alignment bolts and the headaches they may bring, one way to eliminate one pair of them is to install SPL toe rods with the lockout kit. This gets rid of the toe adjustment bolts. The SPL toe rod is then used to adjust the toe. I have them as many others do and they offer a durable alternative.
#22 | |
fo'shizZL1
#23 | |
Shadow Gray '19 ZLE M6
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#24 |
This is incorrect. The 4 large strut to knuckle bolts are not TTY. They are TTA. They are not called out in the service manual as one time use.
Well, I stand corrected. They do, however, have the exact same finish as the TTY bolts for the rear, and didn't cost very much, so it fooled me there. Considering how many times the car was aligned without replacing the legit TTY bolts, I'm glad I had them replaced anyway when the dealer did the alignment recently. |
#25 |
![]() Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
I track two to three trips per year (usually two days every trip). I drive occasionally on the street the rest of the time. On the street, I ride on Pilot Sport 4s tires. At the track I run the F1 Supercar 3R tires. I change to track alignment for every track trip and switch back to neutral/street settings when I'm done. I do this partly for performance but also because running neutral camber while driving aggressive track laps will quickly destroy the outer edge of the tires, particularly the front right for me running counterclockwise (standard) at Thunderhill.
