Old 02-17-2023, 12:30 PM   #15
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Originally Posted by That1guy_tim View Post
I am not. I do live 20min from there. Where can I find the event info?
Wisconsin Camaro on Facebook, or Wisconsincamaro.com.
My Camaro Journal
Old 02-17-2023, 01:40 PM   #16
asthmamax11
asthmamax11's Avatar
This thread makes me feel like I'm way out of my league in here.
Every upgrade done was extremely specific based on real track experience.
I suspect you're an engineer also ?
Very impressive.
I'm curious what caused the motor to get hurt that day.
Were you using the E blend ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 02-17-2023, 01:43 PM   #17
KirillWA
KirillWA's Avatar
Drives: 2022 Camaro 1SS 1LE
Very impressive.
My thinking about this thread was "wow, so many mods, so much time and efforts spend".
More I track my 1LE - more I think "wow, GM engineers made it so track capable from the factory - just following HP supplement guidance is enough to compete with 911s"
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle.
KirillWA is offline   Reply With Quote
Old 02-17-2023, 02:48 PM   #18
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Very impressive.
I might have been an engineer in another life. But this life I'm just a manufacturing supervisor.
What caused the motor to get hurt was an over Rev situation caused by me ( bent some valves, Bottom end is still ok.)
I do run pump E85 from the local gas station
That1guy_tim is offline   Reply With Quote
Old 02-17-2023, 02:52 PM   #19
That1guy_tim
Drives: Camaro 1ss
Engine Mods came due to some bent valves. And if I'm going to open the motor up for repairs I might as well go all out
My car also isn't a 1le, Just a Base v8. Reason I didn't get the 1le was just pricing and knowing I wasn't going to keep the car stock.
The chassis may compete with stock 911's but when I'm trying to chase down modified gt3's and gt2's in my class. I need all the help I can get.
Old 02-24-2023, 11:36 PM   #20
lowandslow88
Drives: 2021 Camaro SS 1LE
really curious to see the aftermath of the bodywork
lowandslow88 is offline   Reply With Quote
Old 02-26-2023, 10:21 AM   #21
Ryanbabz71
Ryanbabz71's Avatar
I ran Putnam last September, it was a fun track (close to home). Probably go back this September.
Sent from my iPhone using Tapatalk Pro
Ryan
Old 02-26-2023, 10:11 PM   #22
That1guy_tim
Drives: Camaro 1ss
You are lucky to be close to Putnam, that track is a blast to drive. The roads to get.to Putnam though, not so much fun with a trailer.
Old 02-27-2023, 07:59 AM   #23
That1guy_tim
Drives: Camaro 1ss
Well this past weekend was full of excitement!
I started installing my GPI cam and Katech oil pump. I am doing this with the motor still in the car. So if you are wondering YES you can remove the oil pan with the motor in the car.
You will need to remove the motor mounts and jack the car up by the front of the trans to get enough angle for the pan to drop out.
Everything was going pretty smooth. until I got to the cam retainer bolts.
3 out of the 4 retainer bolts had stripped out. plus my extractor broke off in one of them! so after hours of carefully drilling, heating, swearing, and praying. I was able to get them all removed!!!
Old 02-27-2023, 08:01 AM   #24
That1guy_tim
Drives: Camaro 1ss
Most exciting part for me was finding out what kind of cam was in this car already.
Out with the old BTR spec comp Cams supercharger Cam.
In goes the GPI Track attack cam! Ready to make some Jam!
Also No idea why my photos are turning 90degrees.
Old 02-27-2023, 11:44 AM   #25
That1guy_tim
Drives: Camaro 1ss
Here's some pictures showing how I "Pulled" the radiator out.
I unbolted it and brought it underneath the upper radiator support.
Old 02-27-2023, 11:54 AM   #26
ZapperZ
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
Those calipers and hats look familiar...
ZapperZ is offline   Reply With Quote
Old 02-27-2023, 12:00 PM   #27
That1guy_tim
Drives: Camaro 1ss
They sure do! They treated me well last season! Thanks again!
Old 02-27-2023, 12:51 PM   #28
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
the build progression from minor to full on track rat is pretty awesome, cant wait to see the latest stage when its done!
SSEssence is offline   Reply With Quote
