01-18-2023, 11:35 PM | #15 |
Drives: 16 2SS Join Date: Nov 2021
It’s a 8 speed car. The tires do need to be replaced. Car has never really hooked that great on the street on the ET SS tire. I have gone as far to replace the stock rear shocks with Kelltrak double adjustables. Still working on finding to right set up but, I know the car needs new tires. Just wanted to know if a 26 would be any faster. Sounds like I will just keep the 28 on it and go from there. Trying to get the car closer to bottom 7s before all the humidity gets too bad in a few months. Thanks for all the reply’s.
01-18-2023, 11:38 PM | #16 |
01-19-2023, 09:02 AM | #17 |
It really depends on your power level if your running NA. If your running a blower 28", I ran the 305-35-20 (28.4) Nitto 555r2s on my NA Camaro before the blower with a best 60ft of 1.72. Still running that tire on the street since we are now making over 700 rwhp with the 2300 and THPSI PI. I ran a 27.7 inch tall Nitto on my C7 NA Corvette and best 60ft was 1.56, ran the 305-35-19 Nitto on the street. I'd still run a 28" on an NA car because looks better and not that much difference in ET and I think you'll see higher top end speeds with the taller tire. But others will disagree and that's ok also. Good luck on your choice.
01-19-2023, 12:57 PM | #18 |
Imo run 26” only on radial n/a 6spd cars
If boosted 28 If bias ply 28 If auto 28
22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28 dragpack - 11.68@122
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
01-19-2023, 01:25 PM | #19 |
If Mickey Thompson made that “28” estreet r dot bias ply as a actual 27.25-27.5 instead of a actual 28.5 we’d be golden
02-01-2023, 07:17 PM | #20 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
02-18-2023, 07:09 AM | #21 |
I saw this post and since checked the info. From what I found, this is reversed, the R is shorter. Can someone verify?
02-18-2023, 07:24 AM | #22 |
The ET Street R radial is indeed 28.1 tall.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15 conversion 1059 WHP/944 WTQ, 9.48@150
02-18-2023, 07:35 AM | #23 |
Wow jegs is usually pretty accurate with weight, rollout, and height stating 27.8. That’s straight from mt tho so I guess it is taller
Was hoping the R was shorter Jegs R top s/s bottom
02-18-2023, 07:39 AM | #24 |
Drives: 98 Camaro Join Date: Apr 2022
02-18-2023, 08:12 AM | #25 |
The 305 45 17 ET street SS is heavier by 5 lbs as well as being a shorter 27.9 inches versus 28.1
02-19-2023, 07:25 PM | #26 |
Drives: 2022 LT1 Camaro Join Date: Nov 2021
Gah dang look at the weight difference. Makes me wish I would've gotten the Rs rather than SS.
10.92 @129.3mph
02-20-2023, 10:22 AM | #27 | |
The height is really gonna hurt times. We’ll see how it does. Gonna load the driveline more as well. For a manual that’s not good. I’m still pouting lol I prob should’ve stuck with 26” but have the 28” sportsman’s up front already
04-08-2023, 04:41 PM | #28 |
Have you guys actually measured these? Now that Ive had these mounted and unmounted, I dont see how they are measuring over 28. I measured with a level and a tape measure. They seem almost exactly stock SS and LT1 height
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 04-20-2023 at 12:38 PM. |
