12-24-2022, 03:41 PM | #15 | |
Katech and now btr would be the only ones I’d consider I don’t care how much less power they make. Otherwise I’d give up more power and use a lt5 cam so I can delete the dod IMO, GPI and Texas speed grinds are at the bottom of my list fwiw
12-24-2022, 07:24 PM | #16 | |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
12-25-2022, 07:40 AM | #17 |
Drives: like an old lady Join Date: Jun 2012
the btr220 really punches above its weight class. it is larger than everyone thinks and utilizes a 4* vvt limiter. i've seen dynos of that cam with several different combos, its impressive. i think that camshaft with a set of cids and carbon r or hi ram would be the best of both worlds. providing great tq and top end power as well. all while retaining cooperative lobes and basically unprecedented (at this point) gen v testing.
edit: on stock heads the btr220 & 225, make within 10 hp of each other and the 225 gave up a little bit of tq.
12-27-2022, 08:37 PM | #18 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I like to see how they are trying with VVT and not just "deleting" it because people think "deleting" things is cool, but I hope they aren't just using it as a marketing technique.
12-28-2022, 09:26 AM | #19 |
Not sure...I recall other companies were selling 4-degree limiter cams before the lock/out delete was the new thing. Then we started seeing stock LT1 head valve seat failure and the heads were blamed. It appears now we are finding out that the stock seats are failing because the valves were bouncing off the seats using dual springs with most of the high lift cams on the market.
It almost seems like companies took lobes that worked on LS stuff and used them on LT and hoped for the best. I am wondering if the 1.8 rocker arm ratio is some of the culprit. As I mentioned before the only other GM small block that used 1.8 rockers was the LS7 and it was plagued with valve issues...even in stock form. The LS3 was solid. Mr. Tooley invested a lot of money bringing a Spintron machine in house to sort that issue out. And he redesigned all of their cam lobes based on that research and development. So, it's hard to really say what is marketing and what is not. But I was right all along when I said a lot of these companies are selling cam kits without any regards to longevity. It's all about power numbers regardless of if you only get 10k miles out of your top end.
2016 NFG 1SS A8
12-29-2022, 12:00 PM | #20 |
Drives: 2022 Camaro, 2014 F150, G6, 70 Nova Join Date: Jan 2022
I just had the BTR stage 3 put in mine. While it was apart, I figured i'd do heads too. Went with Frankenstein heads and upgraded the low side to lt4 pump and injectors.
https://youtube.com/shorts/ie0iQVB4RHk |
12-29-2022, 06:01 PM | #21 |
Drives: 2020 SS Camaro A10 Join Date: Jan 2019
I run GPI stage 1 cam and ported heads, I’ve got almost 39 thousand miles on my build, no issues, I ran 11.2 full weight and stuff in the trunk, Camarofest, Tail of the dragon a few times, 300-400 mile trips, beat on it, drive back knock out 22-25 miles a gallon averaging 80mpg, GPI has it going on
01-01-2023, 09:13 AM | #22 | |
Drives: Chevy Camaro SS Join Date: Nov 2019
2017 1SS:Hi-Ram, FBO, OTR ram air, Circle D converter. Previous PB: 11.07 @124 1/4 7.1 @100 1/8 1.6 60’ w/2” longtubes, 95mm hi-ram, OTR ramair, flex fuel |
01-01-2023, 06:21 PM | #23 | |
You can pick a lobe with less lift and less aggressive ramps but how that all works at the seat can be still to simple.
01-21-2023, 10:39 AM | #24 |
Drives: C7 Join Date: Jan 2023
BTR Gen V cams
The new Gen V BTR cams developed with a Spintron and engine dyno are a great choice. BTR told me that their dyno engine has only OEM LS7 lifters. Other high lift cams recommend GM racing lifters or Johnsons, so that says something about the smooth, controlled valve actuation.
The Gen V 230 is about 14 deg overlap @0.050” lift. Max effort VVT. 225 about 8 deg 220 is 0 deg 217 is negative 4 deg. Largest cam for 5.3 without flycutting pistons. I’m selecting either the 220 or 217 for my daily driver build, NA, E85, GPI ported heads, 13:1, MSD intake, 95mm Soler TB, SW Long Tubes. Targeting 550-600 whp. |
01-21-2023, 02:00 PM | #25 |
Drives: 2022 Camaro LT1 M6 Recaro NPP Join Date: Nov 2021
Agreed. BTR just released a video explaining in detail their development and testing on cams using the Spintron. Very interesting, they seem to be the leaders in development with gen V engine camshaft design. I’m thinking on going with the 220.
2022 LT1 M6 Recaro Red Hot NPP red calipers red seat belts GM short throw shifter GM strut tower brace GM CAI Long tube headers YYZ springs LT2 intake E85 MightyMouse catch can
1992 RS 5.0 5-speed, 1995 Z28 Auto, 1999 WS6, 2007 Trailblazer SS. |
01-22-2023, 08:30 AM | #26 | |
Mill the heads .010 either prays std port or katech Ca pipes Keeping the lt2 intake so don’t need a cam to go past 6800 Still not sure if it’ll go in the a10 or the 1le at this point
01-22-2023, 09:53 AM | #27 |
That should be a nice setup for the street!
2016 NFG 1SS A8
01-23-2023, 10:00 AM | #28 |
Just heard a cammed car on YouTube with stock exhaust and I’m not sure I like it. I’m confused how it changed the tone so much. Seems like the canned cars sound better with headers, unless someone can disprove that.
If that is so, it is coming down to an exhaust decision for me. Do I want to keep stock exhaust or go back to long tubes. Shame it’s coming down to this but there’s a good chance I change location and need the exhaust untouched
