#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
He’s making right about 800whp at his elevation because he’s making it up In boost. He’s running a 75mm and 70mm pulley to account for the boost loss. On that blower that would be 20+ psi at sea level. (Hence the 900+ numbers) So yes 795whp to 800whp is very good at his altitude. But he wouldn’t be able to run that at sea level.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#16 |
I see my, troll Camaro1973, who's on my ignore list, posted no doubt downplaying and trying to minimize every element of my post, as he does on all my posts. I would bet every issue he raises is wrong. He didn't read the chart, or understand what it says.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 12-10-2022 at 04:36 PM. |
#17 | |
You really need to stop acting like a baby on here. I’ve tried to help you a dozen times but you don’t like constructive criticism, unfortunately.
#18 |
He surely will try to minimize the 981 (sea level) horsepower by incorrectly calculating the actual Denver horsepower figure that has to be corrected. So I'll show him how.
Actual Denver hp is corrected as shown on the dyno chart by 1.18. You have to do some simple arithmetic to find the number that, when multiplied by 1.18, equals 981. The answer is (Denver) 832 hp. He'll also misstate boost. The car made 20# boost yesterday and would make 22-23# at sea level, if I have enough fuel pressure. All you have to do is subtract Denver atmospheric pressure of 12.0 from sea level atmospheric pressure 14.7 to get the additional boost the engine would see If it went to sea level, or 2.7 psia. 832 Denver 981 sea level This is beyond rebuttal but this troll will try
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 12-10-2022 at 05:20 PM. |
#19 |
The "troll" is actually putting results into perspective. You made very good numbers indeed, not downplayed in any way—all he's saying is extrapolating actual (physical) performance to a lower altitude with higher fueling demand comes with a big and likely invalid assumption that no bottlenecks would arise when the same car is taken down to sea level. Quoting power numbers the car did not physically make and are heavily extrapolated (well beyond 10-20 hp) is unproven, no matter how appealing.
Feel free to call me a troll, too, but believe it or not, nobody here is out to get you.
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#21 | |
#22 | |
Everything I said about your power in Denver is 100% correct and accurate. 23psi on your SBE not a chance. Even 20 psi is pushing it. I really don’t know what your problem Is.
#23 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#24 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
My car made 714SAE in Denver and 10lbs of boost. Driving it down to sea level in made 13 lbs of boost and 740whp uncorrected with wheels spin on the dyno. So yeah, you’d absolutely make more boost at sea level. That’s a fact. If you have the fuel system to keep up, you’d make quite a bit more power than you are making in Denver.
#25 | |
2020 ZL1LE A10.
#26 |
#27 |
I think I'm going to just post ET and MPH next year. This is not pointing to anyone but the dyno numbers just confuse people and really don't mean anything at the drag strip. Yes, you should tune on the dyno, but you should also log at the track and make changes to go faster at the track and on the dyno. Now I may post after the track of what it made on the dyno and then everyone can have their concerns about that. Wallace racing really has a good calculator for HP/Weight/ET/MPH. Just because a car makes 800, 900 and up it only shows that on the track, I caclulated my DT and I should have only run 137, however I ran 142. So even though I will still dyno I'll let the ET and mph speak for itself. Everyone should post what they want after they start their thread, still proof is in the pudding at the track. JSH, I don't know what a 950 plus rwhp run a the mile high but I'm hoping you'll post some numbers next year to let us know.
#28 | |
But back to dynos. Everyone here posts corrected hp and trq figures. And I'm guessing 5% correction is the median.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 12-11-2022 at 08:12 AM. |
