Old 12-01-2022, 07:25 AM   #15
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Drives: 2023 ZL1 1LE
Originally Posted by JimGnitecki View Post
OP did not mention the ambient outdoor temperature when the cracking occurred.
Jim G
A nice late November day in north Georgia. It started out in the 50s and ended up in the mid 60s.
GA_ZL1 is offline   Reply With Quote
Old 12-01-2022, 10:33 AM   #16
JimGnitecki
Drives: Chevrolet Camaro LT1
So it's NOT related to rubber cracking in cold weather.
Jim G
JimGnitecki is offline   Reply With Quote
Old 12-01-2022, 11:54 AM   #17
AZ_1LE
Drives: 2019 ZL1 1LE
I've never heard of or seen a tire SHRED itself until it's up to full pressure like these 3R's. Have to really take it easy the first few laps and gradually bring them up to temperature and pressure.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 12-02-2022, 09:16 AM   #18
NG329
Drives: Chevrolet Camaro ZL1 1LE
Thanks for the feedback and info. I still like the 3Rs, so I'm going to get a fresh set and then check and adjust the alignment as needed before my next event late winter. Maybe my alignment is off. I have a second set of OE-sized wheels (BC Forged) on which I run just OE-sized high performance street tires for daily driving. 3Rs just for the track. I also switch the 3Rs left to right side between track days to even out the wear. This is all baffling to me because I've run 4 or 5 sets of 3Rs in both hot summer track events in Georgia (90+) as well as on cooler days in fall or spring without this unusual wear pattern.
The only other thing I could think of is that when this happened to me, I did not fully "Run in" the tires. I drove to the track (180 miles) and let rip! The other times I ran these on track they didn't have this happen but I had at least 500-600 miles on the tire. Supposedly, running in the tires (getting fully up to temp) and letting them cool down 24hrs extends the life of the tires.
I'm not sure what your scenario is, but if you threw these on and headed straight to the track that could be a common theme.
I doubt it's the alignment. This happened to me when my alignment was done the same week.
NG329 is offline   Reply With Quote
