Old 01-24-2023, 07:36 AM   #15
Rleo6.2
Drives: Gen 6 ZL1 Camaro C7 Zo6 Corvette
I just ordered the x pipe yesterday. Let you know when it arrives on the quality.
Rleo6.2 is offline   Reply With Quote
Old 01-24-2023, 06:26 PM   #16
bptuner
Drives: 2018 zl1
Originally Posted by manders500 View Post
I get mine tomorrow and I plan on building the primary cat delete. I'll take pictures
great look forward to seeing the results.
bptuner is offline   Reply With Quote
Old 01-25-2023, 12:31 PM   #17
manders500
Drives: 2017 ZL1 Camaro
Unfortunately FedEx is at it again and cannot accurately track their packages. Now there is no ETA.
manders500 is offline   Reply With Quote
Old 01-26-2023, 12:16 PM   #18
manders500
Speedway Motors
They are in
Old 01-26-2023, 03:29 PM   #19
cajunzl1
Drives: 2018 ZL1
So these bolt up behind the primary cats?
cajunzl1 is offline   Reply With Quote
Old 01-26-2023, 07:31 PM   #20
tomster
RedLine
Drives: 2022 ZL1 1LE
Ordered
tomster is offline   Reply With Quote
Old 01-29-2023, 08:37 AM   #21
Chippy
BanHamWatch
Chippy's Avatar
Drives: 21 ZL1 1LE
Looks like it and will be sold out once everyone sees this. I don’t have these but love my secondary cat delete with the AWE that went extinct. Very surprised a company will take the risk producing delete pipes again
2021 ZL1 1LE
Auto
Chippy is offline   Reply With Quote
Old 01-29-2023, 06:21 PM   #22
manders500
A couple of things.
1. The O2 bung was off a little and I had to bend the trans fluid line up and feed the O2 through between the line and the transmission.
2. At this point I cannot install the driveshaft tunnel brace back in as this system doesn't seem to fit up in the tunnel. I have seen Corsa, Borla and others with the brace on. I will be trying again tomorrow to see if I loosen everything and install it.
Old 01-30-2023, 10:45 AM   #23
cajunzl1
Drives: 2018 ZL1
Manders 500
Looks nice, few questions:
1) How difficult was it to seperate the factory pipe from the primary convertor?
2) Did the new pipes fit up to the factory muffler or did you have to cut the pipes?
Thanks
Old 01-30-2023, 11:26 AM   #24
manders500
Everything fit well. I used the new rear pipe to mark where to cut the stock exhaust. I basically just held the new one next to the stock and aligned the hanger and used a sharpie to mark the cutline. I used a sawzall with a metal blade and made the cut. Just watch out for the rear diff and any lines but the cutline was actually just behind the rear diff and the blade was not in danger of hitting anything. The slip connector is pretty long too so there is a room for error.
The stock connections at the front were pretty easy, 2 bolts on the passenger side and the clamp on the driver side. The clamp on mine was tacked to the first cat pipe so I had to cut that off.
Manders 500
Thanks
Old 01-30-2023, 12:15 PM   #25
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Neat...following along.
Old 01-31-2023, 08:31 AM   #26
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Manders 500
Thanks
If you have not done anything like this before, plan on it taking a day.
The stock clamp on the slip connection(driver side) is tack welded...so it needs ground off with a cutoff wheel or something. Also I wouldn't reuse that clamp get a new one. It has a graphite lining that comes apart when you remove it. The Passenger side is a flange connection with a metal gasket...easy peasy.
Far as the rear section, you cut the stock X pipe back by the rear cross member just like you would for any Axle back install. Then use the slip connection adapters and clamps to mate it to the muffler. Nothing unbolts back there as it's all welded together from the factory.
Protip- use 2 bolt lap joint clamps instead of supplied clamps for a better seal.
Old 01-31-2023, 10:36 AM   #27
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
great find ! I may not need them for what I'm doing to my 2023 ZL1, but I just ordered a set. Still showed they were in stock and ready for shipping !
Old 01-31-2023, 10:56 AM   #28
cajunzl1
Drives: 2018 ZL1
Great info
Thanks!
