Old 11-14-2022, 07:17 AM   #15
laynlo15
Drives: 2022 Lt1 A10
Originally Posted by toohighpsi View Post
Greg's car is at about 35% duty cycle on the port. Between port and DI he has enough injector for about 1100 RWHP on full E85.
I've seen these injectors with a stock LT1 high side make 1029 RWHP on full E with a duty cycle of right around 80%.
Just looked at one of my logs and on the DI side we are at 28% duty cycle.
Old 11-14-2022, 06:14 PM   #16
Trochoidal
Drives: 2017 Camaro 2SS A8
Good information here from both of you. Adding the PI sure provides plenty of overhead. Thanks for sharing.
Old 11-14-2022, 06:38 PM   #17
laynlo15
Your welcome. Hope all the info helps others with their builds, whether they use it or not at least they can see what I've done with very few mods. Would be interesting to see if anyone else has run as fast with stock Lt1 and just the blower, you can say its additional fuel mods but it still comes out of the same tank, with stock Lt1 fuel system. Yes it has Jms boost a pump but it just boost the voltage. We actually turned down the low and high side pumps in HPT since we were looking for Volume and not higher pressures. I've learned so much with this that I actually rejected a few years back cause I didn't need it, didn't know anything about it but now I do and a firm believer in what we've done and achieved. New Era made over a 1000 rwhp with an Lt1 stock fuel system. It did have Maggie 2650, drop ins, cam, heads, not sure about the exhaust but that's what Mike was talking about in an earlier post. He was there to help with the port tuning and was blown away it made that much power. Me too.
Old 11-15-2022, 07:22 AM   #18
cjperformance
cjperformance's Avatar
What is the wire that runs through the door jamb? When i removed my intake sound tube, the hole it left in the firewall was pretty large. I ended up running most of my wiring through that sound tube hole.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 11-15-2022, 08:02 AM   #19
laynlo15
That's coming in from the 02 AEM wideband going down to the connector for my AFR that plugs into the dongle at the OB2 port then out to my computer. Just didn't want to run a AFR Gauge.
Old 11-15-2022, 11:22 AM   #20
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Good stuff!!
Old 11-15-2022, 01:02 PM   #21
laynlo15
Good stuff!!
What? Really? Thanks man I appreciate it. Did you like the little dig at the end. HeeHee.
Old 11-15-2022, 03:22 PM   #22
KingLT1
KingLT1's Avatar
Ha...I don't mind it at all. Lol
Your setup kicks ass for sure! I'm predicting 9.60's next spring with a trans tune and low side upgrade.
Old 11-15-2022, 04:48 PM   #23
laynlo15
I'm holding you to your word.
Old 11-16-2022, 08:00 AM   #24
cjperformance
You have to be careful about getting your dongle smashed in the door jamb.
Old 11-16-2022, 08:25 AM   #25
laynlo15
Its tight but the dongle appears to like it. Cheers to all dongles.
Old 11-18-2022, 01:24 PM   #26
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Question as I'm looking to make a purchase of this setup what is the specifics of the fitting size options you have on the site? Also are there any extra fittings needed to be able to add E85 to the mix? I watched the video on youtube about how the fueling is ran but didn't hear anything extra needed for it to work just wanted to be sure.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is online now   Reply With Quote
Old 11-18-2022, 02:14 PM   #27
laynlo15
Size:  641.4 KB From the rear of the long block.
Here is a picture of the routing for my SC. Your intake shouldn't be any different as you manifold will still sit on top of the plate. On the fuel rail you have an option of a -6an or -8an. You can buy the injectors toohighpsi in several sizes. Bosch, Fic, Siemens. I'm using the bosch with mine because the way the 2300 sits that's the only one I can run. You can run any of them. Fic is probably the best.
Size:  205.5 KB From the front of the long block
Hope this helps
Old 11-18-2022, 02:27 PM   #28
WiggyB
WiggyB's Avatar
Awesome thanks for the pictures helps me out a lot.
