Old 02-13-2023, 02:41 PM   #15
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
Originally Posted by cdrptrks View Post
I have heard that there is less air space for brake cooling when running 18" wheels compared to 19".
Also if you get a small rock/pebble stuck between the ZL1 caliper and an 18" wheel it will wear the wheel paint off and possibly wear a grove into the wheel barrel. I believe you also need to consider wheel weight height and placement in relation to the ZL1 caliper to avoid interference with 18" wheels.
I was planning on running the SS deflector for the added brake cooling on the 18's.
But yes it's a very tight fit with the calipers. There's tradeoffs to everything. The Apex wheels are designed to clear the ZL1 calipers, I went with SM-10's.
Slurpee is offline   Reply With Quote
Old 02-13-2023, 05:47 PM   #16
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
It's a tight fit for the calipers, but there is plenty of space for airflow through the rotors.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
