#15 |
![]() Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
Have no problem with blind spots in mine. If mirrors are configured properly you can see everything behind you without having to turn your head. But you have to be willing to set up your mirrors for a 180 degree behind view and sacrifice parallel parking view space. I rarely have to parallel park so mine are always set for a good highway view.
To set them up, drive on the highway in the middle lane. As cars pass on either side make sure as their front headlight disappears from the rear view it gets picked up by the side view. When they leave the side view you should then be able to notice them in your peripheral view. Thats how to confirm they are set correctly. Saved me countless times, and the overall awareness of what is going on around me is fantastic. |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
There's no option for a 3 speed manual on the column, but I may be stretching for an issue.
#17 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Well... Mine keeps eating rear tires...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#18 |
![]() Drives: 2024 Silverado 2500, 2018 Trax Join Date: May 2017
In for all around cameras like my wife’s Lexus. Makes it easier when driving or parking in the city.
More console storage would have been nice too. |
#19 |
![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Biggest complaints I have about my Camaro:
I'm too fat and can't break the 12 sec barrier AND Its not @arpad_m or @Joshintaor's Camaros
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
#20 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
#21 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Stop! We already have been thru that. lol
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
#22 |
Personally,
I disagree with... P.S. I think I've been trolled... ![]() ![]() ![]() ![]()
#23 | ||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I do set my left mirror view to slightly overlap with the rearview mirror. Still not enough to see my own car while driving, but enough to not miss something like a Smart Fortwo or whatever K-car some crazy JDM guy decides to import. The only thing is that when there are people seated in the rear seats of the Camaro, it could be a little tricky and that's when I am glad I have the blindspot monitors. Mine is a 19 SS 1LE so I also don't have the rearview mirror camera. That would also render the issue moot. That said, it's not like there are often people back there. When my buddies ask for a ride, they always ask for the old beater Civic Coupé I have. ![]() Quote:
Yeah you can do it the "traditional way" with shoulder checks, but with most coupés, shoulder checks are pretty much useless. Some of the hatchbacks and sedans also suffer, like the current gen Mazda3 Sport(hatchback). My old Civic Coupé has massive rear windows but that's more of an exception than the norm. With the SAE mirror adjustment, you can skip left shoulder checks and save the right shoulder checks for intersections where you might want to see pedestrians and cyclists. Honestly, I think that's even unnecessary because how much the right view convex mirror's view and rearview mirror's view overlap. And I don't believe the frame of reference is necessary when driving. The complete view without blindspots should tell you plenty enough about if you should change lanes or not, and really far more important than a frame of reference. A frame of reference is perhaps useful during parking, but in my Civic Coupé without backup cam and mirrors adjusted with the SAE method, I also don't have much trouble parking it.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) Last edited by UnknownJinX; 10-28-2022 at 02:11 PM. |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
To me its the overall width of the car. I've had other cars where visibility has been an issue and the Camaro is really no worse. However, I've had more trouble adjusting to the overall width of the car coming from smaller sports cars. Even my C6 didn't seem as wide, but like many other things you adjust to it the more you drive the car.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
#25 |
Wider is better. Pontiac said it, must be true.
#26 |
![]() Drives: 23' Camaro SS 1LE Join Date: Jul 2022
The worse thing I can come up with is the size of the trunk net. I though it just looked small in the pictures.
#27 |
![]() Drives: 2021 SS 1LE SHOCK Join Date: Mar 2021
Would be nice if they had a double DIN stereo. Not possible to upgrade or add features i.e. additional cameras.
All new cars are like this unfortunately. |
#28 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
1. The rear view camera is fine, but wish I could turn around and see everything I needed to (old habits are hard to break).
2. I have a difficult time judging passenger side parking island curb distances while taking a corner. I tend to over swing those just to be safe. If the car was my daily driver, more than likely the above wouldn’t be issues. I guess it’s all what you’re used to. |
