Old 10-28-2022, 09:05 AM   #15
Apexslayer
Drives: Zl1 1le
increase tire pressures, fill tank, add stabil (use battery tender if you have access to electricity in storage, if you don't consider disconnecting negative)
Apexslayer is offline   Reply With Quote
Old 10-28-2022, 10:33 AM   #16
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
Fresh oil change.
Full tank of gas.
Give it a wash.
I put it on wheel savers and inflate tires to 40 PSI. Will periodically check throughout the winter if they're lower than 35 PSI and will add air.
Put on the battery tender
Put on the outside tarp.
Say see you in 5-6 months.
Slurpee is offline   Reply With Quote
