Old 10-26-2022, 01:56 PM   #15
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
If it's just isolated to that one area, fixing each wire would be fairly simple, maybe an hour or so. I've had to fix more complicated harnesses with much more damage.
Note that there may have been damage to components if wires shorted to each other.
Daily Driver mileage update: 64k mi. @ Apr 2026
Old 10-26-2022, 02:13 PM   #16
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Yep, I’m with you on trying a wire by wire repair. For the wire(s) that just lost insulation, there’s a liquid insulator product that can be brushed on. For the others, a couple bucks worth of wire, some heat shrink and a cheap soldering iron kit and good to go.
I do understand that some people aren’t familiar with this type of work…so, good luck either way.
Old 10-26-2022, 02:24 PM   #17
keep_hope_alive
Electrical Engineer
I re-wire vehicles for repairs and restorations. Super tedious but not difficult, just repetitive. It helps I have a BSEE, 25 years of wiring in vehicles, and understand how it all works. Certainly not for most people.
Old 10-26-2022, 02:26 PM   #18
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Some people are not familiar... but even if you are familiar... I think things that would come to my mind anyway.
Is the harness in a spot you can fix the wires decently? Or do you have to be a contortionist to get to them.
You get them all fixed (or you think you did anyway) and there are still issues? Do you take them all back apart to check them? Is it another component that is the issue because two wires shorted out?
Do you have the tools/scanners to troubleshoot any issues if there are issues after you "fixed" the wires.
Just me, but I would always know those wires were spliced and I'd never be ok with that, always concerned something down the road would be an issue. I also would have to disclose that to someone if I sold the car because that is just who I am and how I operate.
I'd have a dealer put a new harness in it. I don't own a $50k car/toy like this because I want to be cheap about a repair. That's just me.
jamala00 is offline   Reply With Quote
Old 10-26-2022, 03:00 PM   #19
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by stormtrooperSS1le View Post
It was the chassis harness correct not an engine harness?
Well I didnt see a part number on the invoice but I just asked AMP and they confirmed that it was the ENGINE Harness.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 10-26-2022, 03:29 PM   #20
Chutzpah
Chutzpah's Avatar
To each their own. I do understand your concerns …but let’s not underestimate the potential difficulty/ effort to remove and install a new harness. What if something else gets damaged in the process (clips, wires, connectors other)? Can you reasonably get to all the connectors? What else needs to be removed? How much time is it going to take?
From my perspective, I’ve worked on very small and up to multi million $ commercial / industrial control systems (under extreme pressure to get things back online, both repairs and installation). That teeny weenie, dinky little wiring harness is nothing that would impede me from at least giving it a go.If you splice, seal and secure everything correctly, the final repair wouldn’t bother me at all. And, I’m pretty anal about my work. So, I’d have no problem telling anyone about the repair….just don’t think it’s a big deal, especially on a depreciating asset …unless there’s hope of placing it in a Camaro museum.
Anyway, there’s tons of people that have fixed their harness in place, whether it be from over size tires, incorrectly routed wiring near the drive belts or melted near or on headers. There’s no one size that fits all… do what makes you feel good.
Old 10-26-2022, 03:32 PM   #21
stormtrooperSS1le
Drives: 2017 camaro ss 1le
Damn the same one that I burned is engine harness? I mean that makes it a whole lot easier so to say if it the engine harness. It looked like chassis harness from the wiring
stormtrooperSS1le is offline   Reply With Quote
Old 10-26-2022, 03:34 PM   #22
stormtrooperSS1le
How far are you from the frankfort area?
If it is the engine harness and not the chassis harness then I feel it is much more doable to just replace the harness. Couple weeks worth of nights in the garage.
Old 10-26-2022, 03:45 PM   #23
stormtrooperSS1le
For my uneducated eyes where I’m this engine harness did the burn occur?
Old 10-26-2022, 07:35 PM   #24
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Whoever did the solder repair and it failed did a poor job. I had a car that had rodent damage and I laid on the garage floor for a day fixing wires and have not had any issues in over 10 years. A properly solder and sealed wire will last. It takes time and patience and is a lot cheaper the replacing the harness and tearing the front end off the car.
dpevans is offline   Reply With Quote
Old 10-27-2022, 08:09 AM   #25
stormtrooperSS1le
I am assuming that in will need to remove the entire interior of the car for this too?
Old 10-27-2022, 12:27 PM   #26
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Where exactly did you burn it? Do you have a better picture? The body harness runs along the passenger rail in the engine compartment from front to back. That is not a harness you want to have to pull out - you would have to pull the IP, carpet, seats - pretty much everything. It runs in one piece through pretty much the entire car. I would say that it is realistically repair only.
Back on the passenger side of the engine, there is some engine harness there too, but only at the front of the engine to the big wiring box. you could replace that if you burned it, although it would be tough.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 10-27-2022, 02:47 PM   #27
stormtrooperSS1le
Geoff it is exactly on that passenger rail. It is the body harness for sure. If I can get up enough to start splicing and soldering we would be ok.
Old 10-27-2022, 03:15 PM   #28
stormtrooperSS1le
Here is a photo of harness next to I think the foil engine harness
