#15 |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
100% agreed, and again, there is always the "burble" tune option.
#16 | |
IMO the crazy pops and crackles are not worth bringing back, the 2016-2018 tune was spot on from this point of view, a few decel pops if you want them but not the obnoxious 30-second firecracker sequence on the 2019+. On a different note, when you say "not as loud", did you just mean the pops or also general loudness? If the latter, inside the cabin or outside? If it's just a bit quieter and only inside the cabin, it could well be the sound tube deletion with your new engine that someone mentioned above.
#17 |
![]() Drives: Chevy Camaro Join Date: Apr 2020
A dealer would not put and older tune back in a car or even mess with it unless Gm had bulletin to do. And it would probably be go to an updated program not an old one. Most independent shops don’t have the ability to flash the ecu. The other thing is maybe the old engine had blown exhaust gaskets or cracked manifolds causing more noise. They fixed that issue when they did the new engine
#18 |
![]() Drives: '19 Camaro SS Join Date: Dec 2019
hmm...never thought of that..I am currently on hold with chevy customer Service ..i doubt they will be very helpful..just didn't know if anyone knew of a specific code or update number that I could inquire about...
#19 | |
Perhaps you got a pre-2019 NOS engine as replacement. https://www.camaro6.com/forums/showthread.php?t=524258 From the repair manual. there is a parameter for the ECM scan tool that displays this: "Engine Serial Number Ignition ON # This parameter displays the engine serial number." |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
No change to diff when going straight, the diff tune is to open the diff clutch more when turning. Doesn’t explain difference and me hearing more after could just be coincidence.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
From factory you get snap, crackles and pops, but after market engine install even if same engine and a tune can remove them
#22 | |
Thanks for the input. |
#23 |
![]() Drives: 2022 1SS Rapid Blue, 6 speed manual Join Date: Feb 2022
#24 |
Drives: Camaro SS 1LE Join Date: Aug 2018
2017 here and very few crackles and pops and then both the car and ambient temperature have to be cold. That’s pretty rare here. At the same time the other day I was watching a YouTuber with his 2022 and the amount of crackles and pops was actually over the top. May be one of those thin line situations.
#25 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Just saying, this is my experience as well. Give it some time for the new engine to break in and the sound will change to what you remember.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
