#15 |
![]() Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
Here's the underhood photo of my Magnuson installation. Can you see if it has that sensor?
Jim G |
#16 |
Petro-sexual
I bet it does. It would intersect the MAP sensor, on the driver's side rear of the blower, and a loom would run, probably, along the passenger's side of the blower case, around the OEM coil harness wire loom. Those are Maggie intercooler hoses, reservoir, and air intake vent tube though.
You could see yourself, though. If you see the driver's side valve cover vent hose, that runs over the snout, and right past the bypass, you can get a flash light and look right in that area and see a brass-bodied sensor run right into the front of the blower case.
#17 | |
Jim G |
#18 |
All the Magnuson kits would come with a breakout harness. Its necessary for the intall.
#19 |
