Old 09-29-2022, 02:16 PM   #15
BeauRichardson
Drives: 2019 Chevrolet Camaro SS
Originally Posted by SATINSTEEL1LE View Post
Hold TC button down for 8 seconds until you see ESC off on the dash. Rip massive burnout and smile while choking on smoke.
is there a difference between pressing the traction control button twice and getting the “competitive mode” thing and holding down the button for 8 seconds?
BeauRichardson is offline   Reply With Quote
Old 09-29-2022, 02:27 PM   #16
SATINSTEEL1LE
Drives: 21 ZL1
Um yes. This would be an RTFM moment.
SATINSTEEL1LE is offline   Reply With Quote
Old 09-29-2022, 02:29 PM   #17
SATINSTEEL1LE
Drives: 21 ZL1
https://youtu.be/CWBzst7Pnto?t=115
Old 09-29-2022, 03:27 PM   #18
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I don't think it's that. my car will do a burn out fine either way... competitive mode or all nannies off.
Old 09-29-2022, 03:35 PM   #19
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
auto ftw
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 09-29-2022, 04:14 PM   #20
BeauRichardson
would have never guessed that they would tell you in an owners manual how to disable every stabilizing failsafe in a car
Old 09-29-2022, 04:55 PM   #21
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
yes 10 speed, but it won’t let me try second gear. if at a stand still it will only let me be in first
Mine is an 8 speed, when in manual mode and I come to a stop it will put me in first. But I can then put it manually into 2nd.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Forged internals
BTR stage 3 cam - Circle Stage 3 trans
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 09-29-2022, 07:16 PM   #22
BeauRichardson
my buddy’s 8 speed is the same way
Old 09-29-2022, 07:36 PM   #23
SATINSTEEL1LE
Drives: 21 ZL1
You wouldnt know because clearly you didnt RTFM.
From the manual and I quote.
Page 214 from this link.
https://cdn.dealereprocess.org/cdn/s...021-camaro.pdf
To turn off only TCS, press and release Y.
The traction off light i displays in the
instrument cluster.
216 Driving and Operating
To turn TCS on again, press Y. The traction
off light i displayed in the instrument
cluster will turn off.
If TCS is limiting wheel spin when Y is
pressed, the system will not turn off until
the wheels stop spinning.
To turn off both TCS and StabiliTrak/ESC,
press and hold Y until the traction off
light i and StabiliTrak/ESC OFF light g
come on and stay on in the instrument
cluster.
To turn TCS and StabiliTrak/ESC on again,
press Y. The traction off light i and
StabiliTrak/ESC OFF light g in the
instrument cluster turn off.
Adding accessories can affect the vehicle
performance. See Accessories and
Modifications 0 236.
Old 09-30-2022, 12:01 AM   #24
BeauRichardson
hm. would have never thought that. anyhow it still doesn’t work so tuning it is
Old 09-30-2022, 08:33 PM   #25
BeauRichardson
Alright today i did some adjusting on the tune and still no success. I adjusted the timing like you had mentioned, and all it did was pull that timing back out unfortunately. I also messed with Accel threshold and that also made no difference. I tried both changes in unison.
I checked out my brake torque limit, and its 6,039 across the board.
Any other guesses?
Old 09-30-2022, 08:37 PM   #26
KingLT1
KingLT1's Avatar
Well if it pulled the timing back out then you might have some torque management stuff going on.
Stock trans tune?
Old 09-30-2022, 11:39 PM   #27
BeauRichardson
Stock trans tune?
not stock but don’t have access to it. any time i try to read it it gives me a stock file. but previous tuner did mess with it. knowing the way he tuned the rest of the car i’d venture to say he screwed that up too
Old 10-06-2022, 05:18 PM   #28
BeauRichardson
little update, i noticed something on a log that was interesting that i must have been overlooking. Whenever i would try to do a burnout, the pedal would be all the way to the floor, but i saw that my TPS percent was bouncing between 38.8-39.2%
Something is telling it not to listen to what the driver is demanding, but all of the driver demand tables seem fine. I'm genuinely stumped at this point.
burnout, cammed, help me, issue, tuning advice
