Old 09-22-2022, 10:51 AM   #15
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Thanks for the feedback, Zach. So just trying to learn here- what is the difference between the factory substrate and a GESI Gen 2 substrate? Why will a GESI Gen 2 have a sustained life and not blow out, whereas a factory cat would, if they are both in the same position, which to your point is further downstream (cooler) from the factory location?
I assume blowing them out is less related to the amount of heat input here and more to the amount of flow restriction? I would think a cooler cat would be less likely to blow out? No?
The heat input is mostly for function/efficiency, yes? I assume any aftermarket cat is less effective than factory because it is farther downstream? Would a GESI Gen2 be any more or less effective at its job than the factory cat if they are both installed in the typical aftermarket location (after a set of long tubes)?
Thanks for the honest feedback!
Mods being installed-
Old 09-22-2022, 01:55 PM   #16
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
I unfortunately am not a catalytic converter expert. If you are going to use a catalytic converter on a modified ZL1 making any sort of power, I would be paying top dollar (GESI 85500 or GESI 85600) to have a huge factor of safety on horsepower ratings. It is worth the initial investment to product your engine now rather than buy an engine later.
A factory C7 ZR1 will blow out OEM cats on track with an OEM tune to put it into perspective.
Katech_Zach is offline   Reply With Quote
Old 09-23-2022, 12:44 PM   #17
L78toLT1
L78toLT1's Avatar
Good info on C7 ZR1 cats failing on track. It looks like, for my purposes, GESI gen2 is the only viable option
Baby Blue
Old 09-23-2022, 02:55 PM   #18
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
For my use, I should be good with the regular gen 2's. That would give me about a 1.7 safety factor over the highest hp I'd ever build up to.
Which is also why I thought the stock ones might be fine for my use. It's a daily driver with the occasional WOT burst and maybe once a year at the drag strip these days. I'm not running it on a road course, so it would see minimal full throttle use.
