#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
This is also a good reason to get corporate involved. You don't need connections to do this, you talk to corporate, I've done it. They didn't just break it and fix it, they broke it and tried to hide it from you. That right there shows they can't be trusted.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
I owned 2021 ZL1 with the A10 for a little over a year before trading it for the CT4V Blackwing last month. The BW is a manual so much more engaging to drive. I am getting a little older so I find I am starting to appreciate the luxury plus performance the Blackwing offers. For example, I like the BW visibility and seating position better. The seats are more comfortable, normal trunk opening and four doors if you need to haul the kids around. I also like the improved cluster gauges, Performance steering wheel with V-Mode and PTM buttons. You also get MyMode, Magride 4.0 is noticeably better and the adjustable brake by wire pedal firmness is actually pretty cool. I also appreciate some of the other features we don’t get in the Camaro like rain sensing wipers, front parking sensors and a wireless charging pad in a usable location. The 15 speaker AKG sound system if very good as well. If you want to go crazy on options you can get massaging seats and a bunch of carbon fiber and if you track the car you can get PDR and HUD. Now the ZL1 is obviously much more visceral and the LT4 just pulls and pulls with the Supercharged V8 soundtrack so when it comes to spirited driving only the ZL1 delivers but to be honest it is over the limit for me and the roads I have access to. In order to enjoy it you have to put your foot in it and triple digits are so effortless in the ZL1, which great but also a bit frustrating. I think if I had the M6 in the ZL1 I would enjoy it more but the gearing is so tall and you can’t really wind them out when you hit 60mph in 1st, 83mph in 2nd and 113mph in 3rd unless you live in the desert somewhere. The 4BW is geared like an SS. Still very quick for the street but more enjoyable gearing ratios IMO. The CT5V-Blackwing is basically a 4 door ZL1. I am sure it is fantastic but they are over $100k, so you lose that performance bang for the buck that the ZL1 offers. So I really enjoy both, it just depends what your priorities are and what you want most out of the car.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
You need to go back to the dealership and start with the Service Advisor and if you don’t get anywhere then the Service Manager. There’s no excuse for what happened to your Camaro.
#18 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
This is a pretty bizarre story…
#19 |
![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
I think as soon as you found a problem the car should have gone right back to the dealer. Now that you have worked on it they will say you did the damage. I wish you luck but I don't think they will fix it now.
#20 |
They shorted me 4 quarts of oil on one of my free oil changes. Long story short I have extended warranty on my engine now. 6 years and 120,000 miles.
#21 |
![]() Drives: 2020 Camaro SS 1LE Join Date: Aug 2020
You should have taken it back and not done anything yourself other than inspect it. Mostly they aren't going to do anything for you and it's going to be on you to replace the pan.
#22 |
I wouldn't be so quick to say that, the helicoil that came out is a pretty good bit of evidence. Plus whatever foolery was inside of that interface.
#23 | |
![]() Drives: 2016 2SS Convertible Join Date: Oct 2017
However, just as an FYI regarding the Heli-coil thread insert in your oil pan, I believe that is OEM on the LT1. I just changed the oil in my LT4 and it has thread inserts in both drains. And, if I recall correctly, my Camaro's LT1 has a thread insert in the oil pan as well. The thread inserts make sense to me since these oil pans are aluminum. Hopefully things will be resolved to your satisfaction. Regards, --KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
#24 |
![]() Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
Maybe have a look at this product...
https://www.timesert.com/html/drainplug.html The service system is setup for bad quality, at least it used to be. Mechanics get paid "book" time. If it takes longer, its on them. If they can do it faster, they can go onto the next job. If they work 8 hours and finish 10 hours of book time work, they get paid for the 10 hours. |
#25 |
PKG4U
That sounds about right.. as someone has said in the past it’s usually always about the Benjamins. Companies almost always willing to do whatever drives the most profit
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” ![]() |
#26 |
376 cubic inches of fun
I suppose this could happen anywhere, but I'm leaning toward some luxury "yurpean" brand next time around.
GM dealers, even my local family owned one, have declined below anything I thought possible. |
#27 |
![]() Drives: 24 2SS 1LE V8 6M Join Date: Aug 2023
I just found a helicoil in my NEW 2024 during 1st oil change and just started a new thread titled “ 2024 1LE LT1 Factory helicoil drain plug ? “
Putting this here in case anyone still has notifications on and can share some insight with me. |
#28 | |
![]() Drives: Chevy camaro, Chevy cruze Join Date: Sep 2023
I came back here to say I've seen others saying they seem have helicoils installed by OEM (you and another post above) so while I'm sure the OP's tech could have cross threaded it I don't think it was done twice.
(Previous, totalled, hit from behind 8/2023) Black 2010 Camaro 2LT, RS. 82K miles.
Blue 2023 Camaro, 3LT, RS. |
