Old 09-19-2022, 09:55 AM   #15
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I have heard good things about quick jacks . I grew up in Atlanta, been in country almost 30 years.
Gen6cyl is offline   Reply With Quote
Old 09-19-2022, 12:03 PM   #16
22SS1LE
Drives: 2022 1SS 1LE 6M
id like to eventually get a quick jack. but who knows when that will be
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 09-19-2022, 12:59 PM   #17
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I put a set of $58.99 jackpads off Amazon under my car and I've used them a few times now but my observation would be that they could be an 1/8th or 1/4" longer as they sit pretty flush with the ZL1 side skirts. Otherwise these work well.
https://www.amazon.com/dp/B07GKXNX3C...roduct_details
Old 09-19-2022, 01:06 PM   #18
Gen6cyl
Is the cross member behind the diff. a safe jacking point?Anybody
Old 09-19-2022, 01:46 PM   #19
22SS1LE
those are the exact ones I bought as well. Had them on the car since the day i brought it home. I have used them already to pull the wheels to ceramic coat my wheels off car but still get weird feeling when i get the car higher and higher on them
Old 09-19-2022, 02:32 PM   #20
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
No, these are the only jack points...
YouTube
Old 09-19-2022, 02:45 PM   #21
20Bluezl1
Yes definitely wish they where a little longer.
Old 09-19-2022, 02:51 PM   #22
WhiteMale
last time I tried to jack a Mustang or Camaro from the front my lo-pro race jack barely fits under it and then didn't have enough handle travel to pump it up so I stopped even trying and I just go off the sides.
Old 09-19-2022, 03:23 PM   #23
Gen6cyl
Thanks ramair02. I have 4 alloy jack pads installed. But I use them for the jack and have no where for the stand. I guess next time I will drive the back tires up a ramp and jack up front center point and use front side points for a stand. Glad I didn't use the rear cross member or the pumpkin for raising.
Old 09-19-2022, 03:32 PM   #24
RamAir02
RamAir02's Avatar
I always use a cheap hockey puck when I'm using a jack. The extra inch gives plenty of clearance so the jack doesn't contact the side skirt.
EDIT: Looking through my photos to find a visual of the jack + hockey puck + lift pad. Found one that I'm (ashamedly) sharing below -- I'm embarrassed since the lift pad is poorly positioned over the jack & puck Do better than I did here!
YouTube
Old 09-19-2022, 04:07 PM   #25
RamAir02
RamAir02's Avatar
One thing to note -- and this doesn't affect your car, Gen6cyl, but posting for visibility for folks with ZL1s or Convertibles (or SS?)...
The above graphic I posted is for "Base" coupes as described in the Service Manual. The ZL1 & Convertible do not cite the front cradle as a suitable jack point. You can see the ZL1 & Convertible graphics below. Oddly, the manual doesn't have a specific document for lifting SS Coupes. My best guess would be SS models also cannot be lifted from the front engine cradle.
YouTube
Old 09-19-2022, 05:15 PM   #26
Gen6cyl
The v8's and I quesss verts have a large brace plate under the front of the car.It is bolted on and costs $250-$300 . I did research on gen 6 bracing.
Old 09-19-2022, 06:19 PM   #27
RamAir02
RamAir02's Avatar
Yeah, essentially don't jack from the engine cradle if your car has that aluminum bracing. Still odd that they have Base, ZL1 & Convertible lifting & jacking docs in the service manual, but not SS
YouTube
Old 09-20-2022, 07:52 PM   #28
22SS1LE
guess i feel a little better. I pulled the wheels today to give the wheels and suspension a good cleaning inside and out
