#15 |
USB Ports for dashcam
Are the two USB ports hot all the time? Or only when the key is on?
I want to use one port for my dashcam because I can hide the wires behind the console easily. |
#16 | |
Hot Camaro
If you want a dashcam with a Parking Mode where it can record if your car gets bumped or similar, you need to wire it to constant power. The Viofo dashcams (one example) have a special hardwire kit that allows them to work this way. |
#17 | |
#18 |
Hot Camaro
Have you measured the power draw on that camera and done any sort of math to know how quickly it will draw the voltage down on your battery in the car? If you want it running 24x7 whether the car is on or not, you should definitely know the impact your car's battery will feel from it.
