#15 | |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I plan to have my car dyno’d at sea level in the coming months, possibly at JRE and we will see how HPFP and injectors work out at sea level. I’ll make more boost and obviously run less ethanol content. I think it’ll pick up some more horsepower but not sure how much. It isn’t much of a detriment to step back from e85 to e60-70. |
#16 | |
You would need to increase your fueling via higher flow fuel pumps, port injection or meth (this last one is strongly advised against), but these shenanigans are typically only done by people who skirt or venture into four digit hp territory (Camaro1973 for example), because after E60-E65 the gains taper off very sharply. As an example, my JRE built and tuned car can go up to E65 with the mods in my sig, and I'm fine with that, injector pulse width using E60 is ~5.4-5.5ms, so there is some safety reserve, and I don't mind having to mix E with 93. For a "normal" street driven Camaro, the only true advantage of E85 over E60-E65 is that you don't need to think and calculate, you can simply dump E85 in the tank. I for one won't spend even more $$$$$ for this tiny bit of comfort and a minimal hp gain.
#17 | |
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#19 |
This is easy in my area, our stations only have E65 to E70 and that's the most I've seen when logging on my HP Tuners. So that works out really good for me. We'll see once I get my new blower on with Mike's toohighpsi port injection.
#20 |
![]() Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Thank you guys for chiming in. It makes a lot more sense now
#21 |
Thank you Al Oppenheiser!
IMO a track car should stick to 93. 99% of the time money spent on a driver mod will beat money spent on a car mod.
But if you must go "E" then know that the stock ZL1 fuel system can handle E60 up to about 650 wheel and still have a healthy lambda. Any more E or HP than this and you're risking a visit from uncle Rodney. |
#22 |
![]() Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
#23 |
Shelf life will be more or less unlimited in the single-digit-humidity of OP's Arizona. But a barrel won't last very long anyway supporting a healthy track habit.
#24 |
![]() Drives: '18 ZL1 1LE Join Date: Sep 2021
For the guys running E60 at HPDEs, isn't the volume of fuel used annoying? On 93, I am getting through almost half a tank on a 20 min session, and pretty easily half a tank on 30 min sessions.
So if I were to go E60, wouldn't that mean I'm filling up/blending at the gas station before every single session? I get that I could bring some of my own gas cans but even then, seems that they would probably need to be filled with E85 before the weekend starts, because it seems like plenty of gas stations nearest to the tracks I've been don't necessarily sell E85. Then I'd still need to drive to the station between every session to blend 93. Am I missing any obvious solutions or is that just the price to pay for more hp? |
#25 | |
#26 |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
I run E40 and the car loves it.
I've seen guys drive themselves crazy over this but honestly it's very simple. Pump 93 is 10% Ethanol near me and I have access to E70. For street driving I start with a full tank of 93 and whenever I get to half a tank I just fill up with 9 or so gallons of E70. Gets me in the ballpark every time. If I get it wrong, as long as I'm in the range of E35 - E45 the tune will still run great. When I go to the track, I carry 20 Gallons of E70 with me and in the morning I fill up with Pump 93. After the first 2-3 morning sessions I'm down to just a little below half a tank. I fill up with two jugs of E70 and I let rip during the 3rd and 4th sessions. Then when I get down to half a tank again, I fill up halfway at the pump and I pour in the 3rd jug of E70. For sessions 5 and 6. Very rarely will I use the 4th jug of E70 unless we go open track or I'm flying out there and buring more fuel than usual. If your MAF is set properly you only need to give attention to the Power Enrichment in HP Tuners. That should get you around Lambda 0.78 - 0.82 and with 93 I like to be around 0.82 - 0.85. Maybe one of the super technical guys will check me on these numbers but so far it has worked for me and nothing has blown up yet. Install a Wideband ASAP to take the guesswork out of things. I just put mine back into my '21 over the weekend and I wish I've done it sooner. |
#27 | |
#28 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
Thanks for the tip. I reached out to them to see if that's something they can do for me. But, I just have no way to transport the fuel so, that'll actually be the hard part.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
