#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
-Engage the parking brake -Jack up car, remove tire assembly -Remove the large axle nut (36mm socket) -Disengage the parking brake -Remove the caliper, rotor and ABS wheel speed sensor -Push axle stud in. As mentioned, it may take a hit with a heavy hammer to break free but you shouldn't have to smack to hell out of it. Use a piece of wood to protect the end of the stub. -Once free, the axle will give a small amount. You can push it in maybe 3/4". -This will give access to the bearing hub bolts. Having someone else push in on the axle while you loosen the hub bolts helps. -Make sure the splines, bolt and axle threads, and all mating surfaces are clean and rust free when assembling. Lightly coat the axle splines with grease. The service manual states to replace the blue washer and nut, part #s in next post. As mentioned above, high strength, high temperature threadlocker is to be used on the wheel bearing hub bolts, GM # 89021297/Permatex #27200
"KEEP THE FAITH"-Fbodfather Last edited by cdb95z28; 09-11-2022 at 09:43 AM. |
#16 |
The fastener torque #s are:
ABS sensor: 89 lbs/in Axle nut: 185 lbs/ft (Edit: I originally had 195 lbs/ft. Service manual says 185.) Wheel bearing:96 lbs/ft
"KEEP THE FAITH"-Fbodfather Last edited by cdb95z28; 03-16-2024 at 02:47 PM. Reason: axle nut torque spec edit I originally had 195 lbs/ft |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Can you post those part numbers?
#18 |
Dohh! Forgot to post them!
Nut: 11612295 Blue Washer:11611965
"KEEP THE FAITH"-Fbodfather |
