Old 07-31-2022, 08:06 AM   #15
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Originally Posted by zig_zag View Post
Where can I find a ball replacement for my stock shifter ...? Or is there one ...? Or can it be done ...?
It should be absolutely doable. My 5th gen had a small screw that held in the shifter knob and many companies make adapters along with their shift knobs.
A google search should yield some good results.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 07-31-2022, 08:31 AM   #16
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
There is a company in Massachusetts called EPCO where I got a marble 8 ball shifter for my 2018 ZL1. I had to also buy a Barton adapter to get it to fit, but I love it. To be 100% transparent, this is NOT a full shifter replacement. The original knob gets replaced with this aluminum shaft and ball on top. That is the stock boot pushed a bit lower.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-31-2022, 01:02 PM   #17
PMCamaro
Drives: 22 ZL1
Originally Posted by MartinLe View Post
Do you know if it actually shortens the throw? At least one member here believes the stock shifter has the same throw.
Yes the throw is shorter
2022 ZL1 M6
PMCamaro is offline   Reply With Quote
Old 07-31-2022, 05:35 PM   #18
atx_traveler
Drives: blue velvet
here's a video of what the shift throws look like. this was shortly after it was installed so it's broken in a lot since then and is a lot smoother through the gears:
https://drive.google.com/file/d/134L...ew?usp=sharing
atx_traveler is offline   Reply With Quote
Old 08-01-2022, 03:42 PM   #19
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Great video. Thanks.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 08-01-2022, 03:51 PM   #20
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Wow, that's a really impressive improvement. I imagine this could be done easier when an engine is removed for a cam install.
Old 08-01-2022, 05:57 PM   #21
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Martin, my suggestion is to install the Hurst shifter if you really want one. Go ahead and do it! 👍
