#15 |
![]() Drives: 2022 ZL1 1LE Join Date: Jul 2022
Sounds interesting, if I'm understanding correctly how it works. I guess I'm stuck with the concern that there needs to be some adaptive learning built in to the ECU. The VVE just seems to be more akin to a mashup of VE and SD with many more variables and preset acceptable ranges to attain whatever accuracy range it's trying to accommodate. I mean adaptive in respect to fuel quality, air density, MAT, IAT, and many more variables not unlikely to be seen in normal operation of a motor vehicle under highway use. So there may be some conditions that allow the engine to operate more freely within the expected normal of the parameters set.
I'm not saying there isn't hard information the ECU is depending on to ensure operation is how it's intended to be, I'm suggesting there should be a small window to allow for some alterations to be accommodated for within the flexible parameters. If not, reflash software is much cheaper and easier to comply with smog standards than a stand alone. Results are what matter most. Not my ideologies for what an ECU should do. |
#16 |
In any case, this has been an fun and enlightening conversation.
#17 | |
Petro-sexual
#18 | |
#19 |
Moderator
I bought one of those “107 effective” TBs as well back when I had a Katech 103 and the 112 was not quite available yet. Same thing happened to me, timing got worse at idle and had some really creepy drivability issues. I sent it back ASAP and got my money back.
#20 | |
#21 | ||
Petro-sexual
#22 |
Moderator
I'm running the 112 now and feel like it was a very minimal improvement over the 103 at this level, even with the 2.9 ported. I will be doing either a Whipple 3.0 or Maggie 2650 this winter and will look at doing a 120 then. But getting the 112 on my 2.9 was a enough of a pain in the butt already...the 112 is huge and pretty close to the upper pulley! No way a 120 is going on a 2.9 lol.
#23 | |
Petro-sexual
