09-28-2023, 01:57 PM | #15 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Before the wave of theories starts here, has anyone contacted Steve personally?
On behalf of the entire Camaro5, so that a bunch of people don't write to him?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
09-28-2023, 07:14 PM | #16 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
He re did my tune a bunch so it was worth doing, I am happy with his tunes so far. I have not reached out to him yet but I probably will in a few days or so.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
09-28-2023, 10:17 PM | #17 |
I spoke with Steve directly a week or so ago. Apparently, there was a misunderstanding with his forum sponsorship so he opted to part ways with Camaro5. He did mention that he is very active on Facebook.
09-29-2023, 03:58 AM | #18 |
Has anyone gotten a tune for him with a cammed car with a lift more than .600? He told me he could not remote tune with a lift .600 or more because it changed the intake psi which would require a dyno tune.
09-29-2023, 04:44 AM | #19 | |
GPI Sales Consultant
Regardless - if you need some help with a very experienced and seasoned remote tuning option for a naturally aspirated 5th gen, we've got you covered here at GPI. Feel free to shoot me a message, or e-mail to andrew@gwatneyperformance.com if we can help.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
09-29-2023, 04:55 AM | #20 | |
I have a question for you Andrew. I'll send you a private message.
09-29-2023, 05:50 AM | #21 | |
———————————————————- On Apr 24, 2021, at 7:43 PM, Steven Leerentveld <dynosteve@rdpmotorsport.com> wrote: Lower manifold vacuum and needs to be tuned on the dyno Thanks Steven Leerentveld RDP Store From: Mike b <swishercg@yahoo.com> Sent: Saturday, April 24, 2021 1:33 PM To: Steven Leerentveld <dynosteve@rdpmotorsport.com> Subject: Re: New/2nd SCT X4 Custom Tune Interesting, what is the reason for the .600 lift remote tune limit? My cam lift is .603intake / .595exhaust Thanks, Mike On Apr 24, 2021, at 11:01 AM, Steven Leerentveld <dynosteve@rdpmotorsport.com> wrote: What are the cam specs because we only remote tune upto 600thou lift Thanks Steven Leerentveld RDP Store www.rdpstore.com From: swisher <swishercg@yahoo.com> Sent: Friday, April 23, 2021 12:13 PM To: Steven Leerentveld <dynosteve@rdpmotorsport.com> Subject: Re: New/2nd SCT X4 Custom Tune Hi Steve, I'll be installing a cam soon to replace the stock cam. What will you need from me to prepare a new tune? Thanks, Mike |
09-29-2023, 06:10 AM | #22 | |
I suspect it's a generalized catch-all that he uses to limit the amount of bigger cams that he has to tune. I can appreciate not everyone is comfortable tuning bigger camshafts remotely, there are some challenges with that, so if you're not confident in the results then probably better not to. It's nothing that would deter us.
09-29-2023, 09:01 AM | #23 | |
09-29-2023, 09:21 AM | #24 | |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
10-08-2023, 04:39 PM | #25 |
"Thanks for sending a link to this thread. Sounds like the same old DynoSteve to me. He's a lot better at making excuses than he is at tuning."
Find a better Pro Tuner like Jannety. Think you got a great tune from him? Have it analyzed by a Pro Tuner like Ted. He just threw 2 crap tunes at me and gave up trying to fix my start issues. Tune for life? - yep it may take that long. I chased a endless slew of his recommended issues to check, all of them a dead end. Go elsewhere. |
01-04-2024, 12:20 PM | #26 |
Drives: 2013 SS LS3, NPP, Blk Join Date: Sep 2012
Same problem here
1LE Suspension Kit, 1LE Strut Brace, dynosteve tune, K&N Typhoon CAI, Goodridge SS Brake Lines, JLT 2.0 Catch Can, NPP Exhaust Mod
01-04-2024, 02:33 PM | #27 |
I don't really want to believe it, but there must be something wrong.
I wrote to him that I needed a new tune for my Camaro (ported intake). He always responded almost immediately, but I waited several days for a response. Nothing so far
01-04-2024, 03:06 PM | #28 |
I paid for tunes for life twice, Once with RDP and once with DSP . Hopefully I don't get screwed.
