Old 10-28-2022, 02:25 PM   #15
RedHot_SS1LE
RedHot_SS1LE's Avatar
Drives: 2018 SS 1LE
For those that want to reset their trim height DIY.
I picked up one of these mainly to do ABS brake bleeds but I found that it also does trim height reset for our cars.
https://www.amazon.com/dp/B09XV8VR35...roduct_details
RedHot_SS1LE is offline   Reply With Quote
Old 10-28-2022, 02:59 PM   #16
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Interesting. If you try resetting it lower, take some before and after photos. I’m curious if that actually works to lower it.
CW3SF is offline   Reply With Quote
Old 10-28-2022, 03:29 PM   #17
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
I don't believe it will lower it. I think it's just to recalibrate our MRC shocks so the shocks operate exactly like they did stock.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 10-28-2022, 04:48 PM   #18
Trochoidal
Drives: 2017 Camaro 2SS A8
If any of you that want the "trim height calibration" done and don’t have luck at the dealer, talk to Xineering. https://shocksims.com/ can sell software/hardware for doing the calibration.
Old 10-28-2022, 05:16 PM   #19
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Originally Posted by Crushed 1LE View Post
I installed a set of YYZv2 springs about a 1000k.s ago. I have a pretty good feel for the car. DRC Controller is arriving next week. I'll zero the height via the controller and then put the OEM controller back in. I'll report on what I experience..... Or don't lol.
DSC Sport programming is quite different from OEM, and zeroing the DSC won't necessarily zero the OEM module, although it could, IDK for sure but I doubt it. I think the only way to get a before/after is to install the DSC, drive it, then zero it and drive it again. Zeroing is only necessary if you lower the car though.
I mostly got the DSC so I could change spring rates via custom springs and have a way to adjust the damping to suit, but the new springs will also lower the car a bit.
I'll post a thread on it soon, I'm sending some OEM springs to a company that makes custom springs and plan on getting a stiffer rate + lower ride height. I called DSC and they said they'd help with altering the basemaps for the new springs as well.
I expect springs to be in the $300-400 range and the DSC is $1400. Not cheap but DSC's Tractive coilover kit w/controller is around $8k and this will be just as good, but not as adjustable.
