#15 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
The biggest benefit to the Adm tank is that it very quickly eliminates any air in the circuit. After I R&R’d my supercharger for porting it only took a few short minutes to completely burp the system. All I had to do was start the car and let it idle with the cap removed from the Adm tank and you can see all the air burping out immediately. The little bit of added capacity is a bonus.
#16 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
Soon hopefully, been busy lately with other priorities and the car is getting retuned. The adm only adds 1/2-3/4 quart of capacity, if your looking for more then definitely don't get this tank. I only added to make burping the supercharger easier
#17 |
Petro-sexual
CSP used to make a trunk tank that was 5 or 6-gallons I think. It’s probably not what you’re looking for, but might be worth revisiting. Maybe. Maybe not.
#18 |
![]() Drives: Z06 Join Date: Oct 2021
will the cordes 1 gallon also serve the same purpose for getting the air out?
#19 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I got home from a 1/2 of driving in warm weather (driving easy for the most part) and was surprised how hot everything was. Even the current expansion tank was almost too hot to touch... makes me wonder how effective the under-hood tanks even are?
I can understand the benefits of putting a larger tank in the trunk... but believe the fender tank would be just as effective... Thoughts?
#20 | |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
The last thing, and this 'could' be added to any tank I suppose, but it is easier to add a larger pump to move the water faster in the rear. The stock pump is very weak in comparison, and at least in 2017, doesn't run 100% of the time the car is on. They might have changed this in later years.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#21 |
#22 | |
#23 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#24 | |
![]() Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
#25 | |
#26 |
Yeah, it quickly turns into just cold water. This has been a common practice for racers for many years. Over 3 years with my current supercharger doing this and no issues. You’ll see TT Lambos, Vipers, etc. dumping ice in for their A2W at the track as well. In the winter it’s good to mix in anti-freeze if it sits where it’s under freezing.
#27 | |
#28 | |
Would using frozen distilled water be better, sure. Just like not tuning the car to make 6, 7, 800+ RWHP on stock internals would be better for them. I have gone through 30 lbs of ice at events, so it’s not practical to freeze that much ahead of time.
