#15 |
Not bad. My best 40-110 last year was 5.08 in 500da and 5.29 in 1749DA.
#16 | |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
I appreciate the response. It helps to have a frame of reference. I think you were running low to mid 10s in the 1/4?
#17 |
Mid 10's on the street with a 1.8 60ft. Never have taken to a prepped track with a drag pack.
#18 |
Mid 10's with a 1.8 60 foot is very impressive. You said before your engine was stock... do you have an aftermarket cam or that stock as well?
#19 |
All stock...here is the run. Second gear launch.
It's at the limits of this wheel tire combo for launches. I was actually able to 60ft a little better(1.75) on the bigger pulley(3.375). It wants to break loose as it rolls out even from second gear, but it still is a little quicker and higher trap with the 3.25 pulley. I am curious to see what it gains this fall since I upgraded injectors. Back to E60 vs E40 and another degree of timing. Log data shows it's making more power. Probably will just spin more but oh well.
#20 | |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
#21 | |
Had a B&M shift kit on a TH350 on an older car with a ratchet shifter and that thing would insta-shift when requested. Spool valves and direct hydraulic action, lol. I don't like all the drive by wire stuff. I get why manufacturers do it, but I can really feel the disconnection.
#22 | |
#23 |
Moderator
Same here. And that’s what you need to do in order to launch in second gear and still make the rest of the shifts automatically.
#24 |
Do you have the stick in TUTD mode for this, or do you just "tune out" 1st gear in normal mode?
#25 |
Moderator
Stick in TUTD mode. Upshift to 2nd when you are stopped at the line. Launch away! No need to touch the shifter again.
#26 |
Was going to look in to how to set that up, but someone resurrected an older thread from KingLT1 already https://www.camaro6.com/forums/showthread.php?t=563629
#27 |
Got a much better 40-110 with the DRs. Im still feathering it in slightly at the start, but loads better.
Prev best was 6.49. So about a whole second faster.
#28 |
nice gain!
