#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
My two cents
OK I assume you got SPLPARTS TOE RODS on the rear. If so I would adjust camber to -2.6 to -2.7. On the front you should adjust to -3.6 to -3.7.
Hotchkiss unfortunately has supply issues so thats why you see more BMR. There's NO DOUBT though that the FRONT HOTCHKISS sway bar is BETTER than the BMR. To make the BMR sway bar on the FRONT to perform properly without splitting the delrin bearings you have to purchase their BILLET bearing holders at 300.00. This item is NOT in their catalog but a special order item BMR Billet Steel Bearing Holders for FRONT Sway bar (SBB010 is a SPECIAL Order part from BMR NOT in catalog, cost is around 300.00)
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#16 |
![]() Drives: Camaro 1ss Join Date: Nov 2019
What is your track experience? If fairly new I can only assume that you were just trying to drive the slow corners too fast.
Also rear tires being from 2017 they might be heat cycled out. But you would also have less grip in the rear during high speed corners.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
#17 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Yeah, the alignment sheet is kinda funky. The picture is showing front toe out but the #s are still positive. The industry standard is toe in #s are a positive value. The rear is showing toe in which is a good thing. As far as the toe #s are concerned, I think those alignment specs are good, assuming the toe has not changed since then. Quote:
I agree here too, I've run with quite a large difference in the life cycle of front and rear tires, including the 3Rs and heck yeah the balance will be off. Details matter.
"KEEP THE FAITH"-Fbodfather |
#18 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Ok so im assuming if I can get a hold of the Hotchkis kit it would be better than using the BMR. https://www.hotchkis.net/product/201...md=432&sm=3069 And I will try those alignment specs. |
#19 | |
As far as the tires being heat cycled that could be it also as I'm not sure exactly how many sessions where on them from previous owner. Out of curiosity I have read guys using 3R till they cord, but how many heat cycles or sessions do you guys do before they get greasy? |
