#15 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Thats good to know... ill have to go back and listen to some idle videos... i recall a few stage 3 cams sounded a bit to aggressive for me. I liked the Stage 2 cams i heard...
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Stages are meaningless, rather know cam specs then silly stages they advertise.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#17 |
Shadow Gray '19 ZLE M6
The walkthrough is outdated since it is for an LS1, but I did heads & cam in my garage on my '00 WS6 using ls1howto.com as a rough guide.
https://www.ls1howto.com/index.php?article=23
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#18 | |
Good to know... But i thought guys were only changing pumps on 2018 cars?
#19 | |
Ok, found a pretty good video of a guy who did the whole job solo in his garage. He tells the story and shows the issues with the oil pan, and even mentions pulling the motor may have been easier. Food for thought I suppose...
I wish GM made it easier to swap cams :(
#20 |
![]() Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
#21 |
![]() Drives: 2018 ZLE Join Date: Sep 2019
I installed my cam at home and if I do it again I am pulling the motor for ease of access.
#22 | ||||||
so he kinda hit on what our thoughts were right off the bat in that video. we ended up dropping the cradle a tad to get in/out.
also be careful of getting the LT1 cam phaser lockout kit, there are 2 springs on the LT4 gear instead of 1 like the LT1. the kit i got sent to me did not work and the spring unwound...causing us to need to buy another. here are some links i saved that we used(it was our first time tearing the front end off this thing) and this guy has quite a few good videos for once you're inside the motor...but again, beware that cam phaser one does not apply to LT4 |
#23 | ||||||||
Thanks for sharing, those are awesome/ Almost done watching this one. He was able to swap the cam without removing the bumper, pan and oil pump. I guess this would work so long you are not wanting to replace the pump or the chain... this looks like the easiest version ive seen yet.
#24 |
So... I am making a list of low cost secondary mods that I would do at the same time as the cam swap in order to budget.
So far came up with... 1. Catch Can 2. Blower Spacer and Blanket 3. Green Gates Belt 4. 160 stat. Should I consider an ATI balancer with 15% pulley as a given? I see Lingenfelter does them as a stage 1... thoughts on anything else I should consider? Katech Oil Pump and chain? Rocker Arms? Belt Tensioner? I know having the blower sent out for porting makes sense as does replacing the heads with ported versions, but I want to capture the more critical options first... Also, if I port the blower... then I need a larger TB, so that gets slippery fast...
#25 | ||
good luck! |
#26 | ||
Good call... expensive but getting rid of the phaser sounds like a good idea... less rotational mass with better seals! https://latemodelengines.com/lt-timi...undle-kit.html
#27 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
I've heard from a good LT mechanic those ls3 type vvt deletes are the way to go. I would recommend the valvetrain when doing the cam, have heard the factory dod lifters are not great as well as the factory needle bearings in the rocker arms. I went with the 174 katech thermostat and haven't had any issues. You're list sounds good, not sure if you need the oil pump with the newer car but wouldn't hurt especially for the price of the unit.
I'd also recommend the ati balancer even if not pushing the boost, I chose the 8.6 lower to try and maintain blower temps but with the lighter balancer I feel it revs a little quicker. |
#28 | |
I wouldn't worry to much comparing the sounds at idle, really doesn't tell you much. Also, many tuners crank up the idle for whatever reason to like 850rpm and the chop isn't as rough. So a stage 3 could idle smoother then stage 2 depending on how its tuned.
