Old 05-23-2022, 01:37 PM   #15
Vigilante375
Drives: 2018 Camaro ZL1
Originally Posted by taylorforschool@gmail.com View Post
Even my gf notices it.. but I’m sure somehow a GM mechanic couldn’t be convinced. You would only notice it on PDR if you watched the revs.. that’s the dead giveaway.. instead of them dropping as they do on any normal shift it’s like there’s a compression build up and it actually stalls the revs and then shoots then up about 100 or so RPM and THEN it shifts. I’ve never used my PDR before so that’s another thing. GM is really good at sticking you between a rock and a hard place
You need an SD card (you can use an micro SD card, you just need the adaptor that it fits into to use it) and it needs to be formatted to FAT32. Follow the first post in this thread to setup the card:
https://www.camaro6.com/forums/showthread.php?t=478942
Once you started the car and ready to drive, open up the PDR on the infotainment screen and press start recording. When you turn the car off, it'll automatically stop recording and save it.
What you're describing sounds exactly like the 3-4 shift but with 9-10. I wouldn't worry too much about it but you can always take it to the dealer and have it documented.
Old 05-23-2022, 01:51 PM   #16
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
Originally Posted by Vigilante375 View Post
Light casual diving, that's a 9 to 10 shift. I don't ever recall my car have this issue or anyone else on here.
Since you have PDR, record what is going on and post it so we can see what you're seeing. I think the sport overlay with be good enough.
I’ll try to figure out PDR and get back to you if you think that will truly help.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 05-23-2022, 02:53 PM   #17
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Trans flush at 15k?
ZX-10R is offline   Reply With Quote
Old 05-25-2022, 05:09 PM   #18
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
When you shift from park to drive or reverse how does it act?
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 05-26-2022, 07:39 AM   #19
PKG4U
Drives: 2018 ZL1
Park to drive is fine. Park to reverse sometime makes a little noise but that’s it.. and that seemed fairly normal to me.
Old 06-18-2022, 10:28 AM   #20
PKG4U
Drives: 2018 ZL1
Update: Trans seems to be getting progressively worse in Auto mode. Manual shifting is still flawless. I will still OCCASIONALLY get a decent driving session in with NO shift errors at all… I can’t figure out what conditions make this possible. Otherwise most of the time when I hop in the car now.. maybe once a week and once on weekends… the car is shifting terribly in multiple gears under many different conditions when the car is left in auto shift. Starting to get scary to drive even though car has no lights or codes. I sometimes get offered mondays off so if that’s the case, she’s going to Chevy Monday.
Old 06-18-2022, 10:44 AM   #21
SATINSTEEL1LE
Drives: 21 ZL1
Did you pull the battery cable off and reset the adaptives?
SATINSTEEL1LE is offline   Reply With Quote
Old 06-18-2022, 10:57 AM   #22
PKG4U
Drives: 2018 ZL1
Yes I did, managed to lock myself out of my car in the process
It didn’t seem to do much, I would say 300-400 miles have been put on since then.
Old 06-18-2022, 08:02 PM   #23
Vigilante375
I'd still like to see the PDR video of said problem. Because it seems like you have either a bad trans, bad TCM or ?
Old 06-18-2022, 08:41 PM   #24
PKG4U
Drives: 2018 ZL1
I never took the time to do that but my guess is it’s obviously one or the other of the above stated. Not happy at all but from what I can tell this is a rare occurrence. Hopefully either way it’s easy for Chevy to sort out and I report back happy soon
I have certified service on top of manufacturer on top of certified pre owned so I should be covered at 15k bought at 12k
Old 06-20-2022, 09:07 AM   #25
PKG4U
Drives: 2018 ZL1
THANKFULLY, right as my attempt to show the mechanic my trans issues was about to fail… just at the end of our ride the shifting got a little clunky. He went into the office and told the service people that “ he acknowledged an issue with the trans”. Sounded like warranty speak for “we got this” so fingers crossed. Will report back with findings as soon as Chevy tells me.
Old 06-28-2022, 07:00 PM   #26
PKG4U
Drives: 2018 ZL1
UPDATE: New valve body arrived today. Hoping that this will fix the issue
