Old 05-20-2022, 01:37 AM   #15
synolimit
Drives: 22 ZL1 1LE A10
Originally Posted by mano_camaro View Post
Not trying to jack the thread, but just went to get a track alignment done today and this is the best a speed shop could do with no drive-on lift. They depend on 4 post lifts only and some dollies under each wheel.
Does the diagram look remotely close to a track alignment? I gave them the performance track prep sheet. But couldnt get the fronts to -2.0 without flipping the struts.
No not close. Front way off but the rear still needs more.
synolimit is offline   Reply With Quote
Old 05-20-2022, 07:11 AM   #16
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
The rear looks like it's at the recommended spec, but front camber isn't there. Car will probably understeer a lot with that alignment. There's no way to "flip the struts" with OEM parts, that's only on the ZL1 1LE top mounts from the factory. I'm guessing the alignment tech only loosened the strut-knuckle bolts and didn't push them out to disengage the splines. Without that step they wouldn't have been able to do any real camber adjustment.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-20-2022, 08:40 AM   #17
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
THat's the sort of work that I'm shopping to avoid which is it's in the green and that's good enough, which it is indeed OK but it's not what you want. Shops don't want to or don't know how to get the - camber and then adjust the toe.
I think that for a "speed shop" that looks terrible, I might expect that from some mainline auto shop but you put "speed" in your name and it's
Old 05-22-2022, 12:52 AM   #18
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
Yeah, i did notice a little understeer while in touring mode. I forgot to mention they broke a rear camber bolt and charged me for the replacement. Total i paid $220 for that alignment job.
Unfortunately it was recommended to me by another fellow camaro owner, but im staying away from that shop for sure. Seemed more of a "Backyard Mechanics Den" than a speedshop given the way they were working all sitting indian style under the car and no drive on lift.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 05-25-2022, 10:43 PM   #19
Camden45
Drives: Chevrolet Chevy
Snapping bolts on a brand new car and charging the customer for it? What the hell?
Camden45 is offline   Reply With Quote
Old 05-27-2022, 08:22 AM   #20
19SW1LE
Drives: 2018 LT 1LE
Damn that sucks. PM me and we can adjust your front camber if you want.
19SW1LE is offline   Reply With Quote
Old 07-05-2022, 08:02 PM   #21
LESS1
Drives: Chevy Camaro
Give these guys a call they are in Sterling, VA and will get you sorted out.
https://www.rrtautomotive.com/
LESS1 is offline   Reply With Quote
