Old 06-21-2022, 09:34 AM   #15
Bud357
Bud357's Avatar
Drives: 2022 Camaro LT1 M6 Recaro NPP
Awesome, thanks for the update. I will be installing mine next week.
2022 LT1 M6 Recaro Red Hot NPP red calipers red seat belts GM short throw shifter GM strut tower brace rotofab CAI GM sway bar kit secondary cat delete
1983 Z28, 1996 Z28, 2018 SS Hot Wheels
Bud357 is offline   Reply With Quote
Old 06-21-2022, 09:54 AM   #16
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Glad to hear you guys are happy with these. They were great on mu y 5th Gen, and will be going on my ZL1 next year when I get it.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 06-22-2022, 05:30 PM   #17
xqwisit23
Drives: 2019 Camaro 2SS Vert
Did anyone buy from SummitRacing or directly from Stainless Works? Checking to see if anything more is required if buying from Summit
https://www.summitracing.com/parts/s...hcsts#overview
xqwisit23 is offline   Reply With Quote
Old 06-23-2022, 11:31 AM   #18
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
This set looks complete to me, even comes with gaskets. On the 5th Gen it was recommended to use OEM gaskets. That's all I would confirm if I were you.
Old 06-24-2022, 06:34 AM   #19
Bud357
Bud357's Avatar
Yes I would get OEM header gaskets that is what I will be doing. Part #12657093
Old 06-24-2022, 01:14 PM   #20
crewchief25h
Drives: Chevy Camaro 1LE
My car has 1200 miles, so I reused my originals
crewchief25h is offline   Reply With Quote
Old 06-29-2022, 07:09 AM   #21
cam765
Drives: 2019 SS
Just finished my 1 7/8" Stainless Power install this weekend. Was a bit of a pain, but got it done. Driver side is easy, just need to remove the short intermediate steering column piece. Passenger side was tougher. Need to relocate the coolant reservoir and I ended up having to remove a motor mount nut and tilt the engine a bit to drop in the header.
cam765 is offline   Reply With Quote
Old 06-29-2022, 10:06 AM   #22
Bud357
Bud357's Avatar
I have the driver side done and am now working on the passenger side. Yeah it’s a bit tougher.
Old 06-30-2022, 03:48 PM   #23
crewchief25h
Pull the valve cover on the pass side. Much easier than jacking the engine around
Old 07-01-2022, 06:23 AM   #24
Bud357
Bud357's Avatar
Got it all done. Really wasn’t too bad of a job even without a lift
Old 07-01-2022, 08:24 AM   #25
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Awesome man! Thanks for the feedback, I think I will tackle this install myself as well when the time comes.
Old 07-24-2022, 10:16 AM   #26
Bud357
Bud357's Avatar
Finally made it to the dyno and got the car tuned. Long tube headers and CAI, 441 hp. Pretty good I think.
Old 07-24-2022, 10:43 AM   #27
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
did you drop in from the top???? Passenger side, and drivers for that matter usually feed up from the bottm......
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 07-24-2022, 12:46 PM   #28
Bud357
Bud357's Avatar
I installed both sides from the top. I removed the steering shaft on the driver side and removed the valve cover on the passenger side for clearance.
