#15 | |
Not likely. GM tuned both the LT4 and LT1 to live off the knock sensors. They show knock regardless of what fuel you run at the pump. The knock sensors are setup to be overly sensitive. likely to protect the engines from those who will put 87 in them.
#16 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Not sure about the LT1, but the LT4 does not like 91...
My ZLE not only runs better but makes so much more power on E50... Plenty of E85 around so-cal... I suggest you call TED @ JRE for his FlexFuel kit and remote tune package... WELL worth the $$$
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#17 |
![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Nov 2009
Its not a daily driver, some times it sits for 3-4 weeks at a time. Just don't want that ethanol breaking down and gunking up injectors etc. I have never liked ethanol.
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
#18 |
[QUOTE=KingLT1;11169206]I am not sure why. These cars are tuned for E10 fuel. And E10 is higher octane then 93. So you are only going backwards.
Typically any E10 fuel is created by blending 10% ethanol with a lower octane base fuel to reach the desired octane rating. Thus 93 Octane is typically 91 octane gasoline blended with 10% ethanol. In other words, the 10% ethanol blend is roughly a 2+ octane rise in octane rating. You are getting what the pump advertises, not some octane 2 points higher.
2018 ZL1 M6 NGM
#19 |
Ah, I see, thanks. I'm not an expert, but don't think 10% ethanol would be enough for that, otherwise this would plague a large number of (non-daily driver) vehicles.
#20 | |
You are probably correct on that, and I will probably start fueling up on 93 with E10 a little more often based off what I read on here I am probably overthinking it.
2018 ZL1 M6 NGM
#21 | |
#22 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I have had e10 go bad that I use for dirt bike and mower.It might have been over a year old . Now I use non ethanol in them ,which I can only find in 87.
#23 |
Dirt bike and mower isn't the same thing. They don't have fuel system components designed to handle Ethanol fuels like newer GM vehicles do. I always put Lucas Ethanol treatment in my gas cans for 2 and 4 stroke engines.
#24 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#25 |
#26 |
![]() Drives: A10 ZL1 Join Date: Mar 2018
I would add a can of boost and if all I could get was 91. Of course, mine is not a dd
#27 | |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
#28 |
I suspect there are a lot of V8 drivers doing the 93 vs lower grade experiment given current fuel prices. probably not the type to be members here though!
as others have said, the ecu will just pull timing and run off the lower grade fuel. No CEL or other warning will pop up. Manufacturers plan for this scenario. |
